P1511 Code
Old Apr 10, 2023 | 11:23 AM
JayJay11's Avatar
JayJay11
Stage II
Default P1511 Code
So my bike has gone into safe mode from having a bad battery and trying to jump it with a vehicle. Yes i didn’t know before but i do now that is a big NO. But i have changed throttle actuator and twist sensor and even checked cleaned and greased all the plugs and still is throwing the 1511 code. What else could it possibly be throwing that code and what would i need to do to fix it? Thanks
Old Apr 10, 2023 | 08:56 PM
rideonva's Avatar
rideonva
Could be bad news - ECM. Try this procedure see if it helps or if other codes are set.
Old Apr 10, 2023 | 09:23 PM
JayJay11's Avatar
JayJay11
Stage II
it’s not the only one still popped up. For all i have read and talked to techs, i believe i have a bad bcm. i am going to get one and put it on and i will update my post. thanks!
Old Apr 11, 2023 | 01:35 PM
FLTRI17's Avatar
FLTRI17
Sounds like you toasted the ECM when the bike was jumped BUT a dealer can attempt to reprogram (return to stock) the ECM if it is corrupt and not “bricked”.
Bob
Old Apr 12, 2023 | 08:00 AM
bustert's Avatar
bustert
why can you NOT jump a harley??? do it all the time.
the big issue is to jump battery to battery, the supply vehicle not running. after about 2 minutes, start your machine.
went to the farm and cut the pasture, went to start the hd and little power. no jumper around so i got a piece of 12ga house wire and used it to the tractor, walla, ride home.
matter of fact, hd even sells a jump pack. jump packs are voltage boosters not an amp machine. volts gets it started, amps keep it rolling.
Swh1968
Jul 29, 2022 12:14 PM
07UltraGuy
Dec 21, 2021 06:58 PM
Malapropos
Aug 11, 2016 12:23 PM
cgrnh
Aug 19, 2012 07:06 AM
WOS Bishop
Aug 22, 2011 11:38 AM
