Fuel problems
Upgrades T-max -07 ,cam -19 ,103 -20 ,.50mm se tb 21 .
aug. 23 . Stops when I hit the throttle ,starts fine after a minute. Take it easy home ,couldn't find anything wrong .
Next weekend tested a little ,100 km whidth all kinds of ridning styles .no problems, then parked it for 2 hours. Dead . Towed it home, changed sysrelay and fuel filter. starts again .
Next weekend, make a trip whidth a friend 150 km ,stopped for an hour. started fine ,let it idle ,give gas and stops again . Towed it home . Did nothing .
Starts fine a weekend later so i went to a shop ,checken for codes and fuel pressure .,Ok .
Can maybe be crank sensor was their suggestion so i bought one .
My ears told me that the fuel pump had adifferent sound than stock. So this winter i get new one ,
Started ridning in april again ,all good .
1000 km later stops again , checked and there is sparks but no fuel . Towed it home .
Tried the stock ecm , no start .
Have now ordered a fuel pressure regulator, hoping that is the solution !
Could a f.p.r. act like that ? Good/bad/good/bad....?
Thougts?
Erik
Thougts?
Erik
Inte the tank again and found a fuel filter in bad shape, looks like the glue had melted.
Cleaning time ,filter is only 3 months old .
