PCV Tuning advice?
Old Aug 7, 2024 | 08:11 AM
V.231's Avatar
V.231
Stage II
Default PCV Tuning advice?
To start, we've got a '99 FLHRCI running some old V&H 2-into-1 Pro Pipe, and a, SE Big Bore Kit EXCEPT the Stage 1 ECM (because dad ordered each part separately thinking that he didn't need the ECM cartridge cause he had a Fuelpak and a guy who knew how to tune it). Fast forward to now, he's had to replace the Fuel Pak with a Power Commander V some years ago and it only now occurred to him that it hasn't been tuned.
I've been helping him out and checking out DynoJet's website and found two maps that match our setup closely enough, the difference being that one assumes Screamin' Eagle slip-ons (I assume for the stock dual exhaust setup), and another that has the correct exhaust but assumes either a stage 1 or stage 2 ECM.
My question is, what's the more important part to match with the tune? The exhaust system, or the ECM? I've been warned that getting something wrong could result in detonations. I've brought up getting the ECM tuned directly at a Dyno shop, but he doesn't want to cut the exhaust to weld in the O2 Sensor bungs we'd need.
Thanks.
Old Aug 7, 2024 | 01:40 PM
marcodarq's Avatar
marcodarq
A) the bike can be tuned at a dyno shop without cutting and welding bungs.
match the map to the exhaust.(in your case)
you are much better off taking it to a reputable tuning shop and having it dyno tuned, its worth it.
m
ajk511
Mar 16, 2016 12:29 PM
roadrash3
Jun 18, 2013 08:21 PM
Dissent89
Jan 19, 2013 05:59 AM
kevjo
Oct 31, 2012 09:40 PM
victoriouz
Jul 18, 2011 08:18 PM
