Stock fuel pump flow rate and pressure .
Old Aug 19, 2024 | 06:37 PM
Kwikwilson007's Avatar
Kwikwilson007
Default Stock fuel pump flow rate and pressure .
I’m in need of some information ..
I have a fresh build on a 2007 Softail 124 inch twin cam .. originally a 96 inch . I’ve been having fuel pressure issues and I’ve replaced everything inside the tank with new . The pump I used was from a company called The Fuel pump Factory . It’s supposed to be an Oem type replacement , plug and play . I’ve replaced the problematic plastic fuel pump housing with a Trask billet type to eliminate any leaking.. been inside the tank with a bore scope to insure it wasn’t leaking anywhere. It’s not leaking.. But I’m only able to get 53 psi of fuel . It’s steady and holding while I change rpm’s .. And it’s supposed to be 58 to 62 psi . My question is , how many lph does the Oem pump deliver and Am I right , thinking I need a bigger fuel pump . Or maybe just a better one … The bike has the HPi 62mm throttle body with the yellow band 6.2 injectors.. So I’m thinking I need a pump that delivers more fuel . More than the Oem ..
And if So , where would be a good place to find a pump that’ll fit without a lot of modifications , if any ? Thank you in advance
Old Aug 19, 2024 | 08:06 PM
Ed Ramberger's Avatar
Ed Ramberger
Pressure is set by the regulator. Maybe your new regulator is a little low.
Old Aug 19, 2024 | 08:58 PM
Kwikwilson007
I’ve tried two different regulators and it’s at the same level . So that’s why I’m looking at the pump .. It’s having a hard start issue when it’s at operating temp . And with the pressure at 53lbs , I’m thinking it has to be the low pressure.. like I mentioned in the original post . Everything is new .. The throttle body , injectors, the pump , the filters , the regulator and the regulator housing. And All the lines inside the tank , with a new quick release fitting at the base of the tank . Even the engine is new . I feel like I’ve covered All bases . That’s why I’m leaning towards the pump . Plus , the larger injectors and throttle body . I tested the pressure at different rpm’s while running.. so I’ve checked it closely
Old Aug 20, 2024 | 03:18 PM
Max Headflow's Avatar
Max Headflow
One thing to note is that you really need to look at the fuel pressure while the pump is running.. On the 3 efi bikes I owned, the pressure would be around 60 when running but as soon as the pump stopped they would drop to 50-55 and hold.. IMO this is good..
Old Aug 20, 2024 | 08:56 PM
paulmedford's Avatar
paulmedford
not enough lph would causing leaning out when running underload. The bike would hold back and run hot.The fuel pressure seems good ( especially for starting), you need to tune the bike for the start issue.
Old Aug 21, 2024 | 12:47 PM
Kwikwilson007
You see , mine is running at 53 , throughout different rpm ranges .It holds close to that , maybe 50 after you shut it off also .. And .. It’s supposed to be 58 to 62 . I’ve got a quality gauge and I’ve went inside the tank with my bore scope to be sure there are no leaks . And there’s none .. I’ve tried three different regulators .. So I’m thinking the pump just isn’t delivering … Any thing to add ?
Old Aug 22, 2024 | 12:53 PM
marcodarq's Avatar
marcodarq
it sounds like the only thing to do is put a different pump in it and run your tests again and compare results.
m
Old Sep 1, 2024 | 02:24 AM
Highway Handler's Avatar
Highway Handler
Maybe the aftermarket pump is the problem. My stock pump is made by Denso and they are good.
Old Sep 1, 2024 | 02:45 PM
Highway Handler
https://www.densoautoparts.com/fuel-pumps/
Joe Bill
Jul 6, 2023 08:47 AM
Nelson64
Dec 31, 2022 02:48 PM
junkyardscrounger
19
Sep 21, 2022 07:52 PM
1957buick
Oct 25, 2016 12:07 AM
RjCapp
Exhaust System Topics
May 15, 2007 11:34 AM
