Tool for testing fuel pressure
Old Mar 6, 2025 | 07:50 AM
roussfam's Avatar
roussfam
Default Tool for testing fuel pressure
I watched a YouTube video where the person making the video has a kit specifically for Harley Davidson's that has specific adapters to connect to the OEM Harley fuel line. It looked pretty straightforward.
My local Napa has a kit you can borrow for free but it is for automotive applications. I had a look, I see it's got a ton of adapters, but I don't know if anything is compatible with Harley.
Has anyone used one of these kits from an auto parts store to test fuel pressure on their bike or do you need a Harley specific one?
Thanks guys, Jim
Old Mar 6, 2025 | 08:53 AM
Jackie Paper's Avatar
Jackie Paper
I had Autozone's loaner tool. It didn't, but a Harley 62900-01D Harley tank to Throttle body hose cut off addressed the fix.
Under $50 for a seldom used tool is cool. However I had that hose and a 2012 Throttle body with a damaged thread for the air filter in my too good to throw away category box.
If one goes that route, check your model. I am not sure if all FI tank connections are the same.
Old Mar 6, 2025 | 10:10 AM
jake24lt's Avatar
jake24lt
https://fueltool.com/products/harley...ssure-gauge-2/
Old Mar 6, 2025 | 12:08 PM
roussfam's Avatar
roussfam
.... Has anyone used one of these kits from an auto parts store to test fuel pressure on their bike...
Old Mar 6, 2025 | 12:34 PM
jake24lt's Avatar
jake24lt
Yes, I have the one I posted . Works as it should pretty simple, hook it up inline between tank fitting and the fuel line. Good feature is, you can run the bike down the road and see the actual pressure under load. Of course someplace without things to run into !
Old Mar 6, 2025 | 03:36 PM
Rusty Springs's Avatar
Rusty Springs
I bought a kit on Amazon that may be similar to what the part store has. I've only used it on Twin Cams. The adapter gets plugged onto the throttle body and the oem hose can be turned to connect to the tee on the adapter.
It's a little bulky but works for me.
https://www.amazon.com/dp/B07LF26ZTJ?ref=cm_sw_r_cso_cp_apan_dp_7CNF81848RST5KJNK0C1&ref_=cm_sw_r_cso_cp_apan_dp_7CNF81848RST5KJNK0C1&social_share=cm_sw_r_cso_cp_apan_dp_7CNF81848RST5KJNK0C1 https://www.amazon.com/dp/B07LF26ZTJ?ref=cm_sw_r_cso_cp_apan_dp_7CNF81848RST5KJNK0C1&ref_=cm_sw_r_cso_cp_apan_dp_7CNF81848RST5KJNK0C1&social_share=cm_sw_r_cso_cp_apan_dp_7CNF81848RST5KJNK0C1
Old Mar 6, 2025 | 04:58 PM
Lonewolf176's Avatar
Lonewolf176
Good call on running it down the road as pressure can drop with rpm. Here's a before and after.
Old Mar 8, 2025 | 08:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I purchase fuel tool and just used it the last few days and it works perfect. It helped me to resolve an issue with an injector leaking down..
@Lonewolf176
How did you graph the fuel pressure?
Also I'm curious if anybody makes a regulator that's adjustable because I know in the fuel oil heating world we've brought oil pressures up to 105-106 psi for better atomization of the fuel which increase the efficiency a lot.. So I'm wondering if that would work with a Harley..
Old Mar 8, 2025 | 04:45 PM
Lonewolf176
It's a Fuel Tool that plugs into the dyno stack. Instead of the gauge it has electrical plug.
Cap77
Jan 5, 2025 08:16 PM
Shiver905
2014-2024 Touring Models
Jul 17, 2024 09:06 PM
Lone Watie
Apr 3, 2013 09:56 AM
Red Road King
Jul 17, 2010 11:03 AM
rbabos
Oct 12, 2008 06:45 PM
