sert error message
Old Oct 10, 2007 | 08:35 PM
murphdog's Avatar
murphdog
Default RE: sert error message
Mud, try these port settings. These are what I use with data mode and a variety of other stuff.
Joe, my check engine light doesn'tgo on and off, but my battery light does. Doesn't seem to affect anything, but there's a bug somewhere.
[IMG]local://upfiles/2952/37B18BE9879A4DA08A357A62184D86C2.jpg[/IMG]
Old Oct 10, 2007 | 11:15 PM
mud's Avatar
mud
ORIGINAL: murphdog
dog, I'll try those settings out tomorrow,
and see what happens.
mud
Old Oct 10, 2007 | 11:17 PM
mud's Avatar
mud
You've lost me now Joe.
I do not see any of that when
right-clicking on one of your usb HUBS in the hardware list
mud
ORIGINAL: Lowcountry Joe
Mud,
The serial port does not have a power managment option like the USB hubs do. If you right-click on one of your usb HUBS in the hardware list, and go to Properties, you will see a "power managment" tab. It' s there you can uncheck the box allowing the computer to turn off this port.
So, the serial port will be hot or active all the time. That's why serial port (and parallel port....printer) connected devices are not "hot swappable" as is the case with USB devices. You can unplug a USB device from the computers usb port with the computer running and then plug in another USB device in the same or different usb port on your computer and the computer does not mind at all.
Try that with a serial port and all hell breaks loose. So it's a good idea to always have your serial cables plugged into the back of the computer and the other side of the SERT 's cable plugged into the data dongle on the bike BEFORE you boot up the computer.
I wish I knew why my engine light is coming on during data runs...hummmm
Regards,
Joe
TickTock
May 29, 2009 04:12 AM
fireman403
31
Mar 25, 2008 10:18 PM
Josey Wales
Jun 10, 2007 03:18 PM
Road Glider
Dec 7, 2006 10:53 PM
hddeluxe
Mar 19, 2006 12:12 PM
