PCIII timing
Old Oct 5, 2007 | 11:36 PM
notarheli's Avatar
notarheli
Default PCIII timing
I've seen this stated different ways and I found it curious. The PCIII alters timing similarly as it alters the fuel scheduling. So, when putting numbers in the timing cell, is a positive number advancing the spark even more than the ECU timing or is a positive number decreasing when the spark occurs essentially retarding the timing?
Old Oct 6, 2007 | 05:33 AM
glens's Avatar
glens
Default RE: PCIII timing
As with the injector duty cycle part of the map, + is more, - is less. More timing advance, less timing advance.
xwhyz1959
Dec 10, 2012 06:11 PM
jackinthebox
Apr 8, 2012 11:07 PM
I8AGSXR
May 20, 2011 07:19 AM
bdbaggr
Oct 22, 2010 10:08 AM
asmacsbob
May 11, 2007 02:25 PM
