Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have retrieved 2 codes from the ECU a 23 and 41 code. The 23 is a front injector open low or high and the 41 is CKP sensor intermittent. Does anyone have the troubleshooting steps for these codes? Do I have to take it to the stealer? I have checked and cleaned the connectors with no luck. Both the codes are active. TIA
Seeing as they are "Active", meaning the CEL is on all the time, it could be anything from a loose wire, faulty Relay, Faulty components (Injector/CKP) to a faulty ECM.....
Either invest in an ELECTRICAL DIAGNOSTIC'S Manual, or take it to a shop.....
DTC's only tell you what triggered... The manual will tell you how to narrow it down to what is the fault, and how to rectify it.....
BTW... Welcome.. Please take a moment to post an intro in the NEW MEMBERS SECTION at your earliest.....
How do you retrive fault codes on an 02 fueli ? Would it be the same manor as on a V rod by holding speedo button and turning ignition on . If so it wont work for me
