Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I just bought an '08 Nightster and want to get a battery tender for it. I also have a security alarm on the bike.
My question is if I disconnect the battery to install the Ring Terminal Harness for quick connections, will I need to have any codes reset on the bike or security alarm?
My VW codes have to be reset if I disconnect the battery and I was wondering if the same was true for a motorcycle.
I don't know specifically for the 2008 bikes, but for the earlier bikes without the passive alarm system, you could disconnect the battery and not loose a thing.
You might want to check your bike for an existing pigtail. More & more dealers are installing pigtails as part of setup (for their benefit mostly). They like to use chargers in their showrooms at night.
