crane ignition
Old Jan 6, 2008 | 11:13 AM
BONERACIN's Avatar
BONERACIN
Default crane ignition
I AM PUTTING ON THE CRANE HI-4TC IGNITION ON MY 04 DYNA (CARBED). I ALREADY HAVE A GOOD SET OF GEAR DRIVE CAMS,HIGH FLOW AIR CLEANER, AND PIPES. ANY SUGGESTIONS ON WHERE I SHOULD SET THE TIMING. I AM SURE THAT IT COMES WITH A GENERIC GUIDE TO SET IT. BUT ALOT OF TIMES THEM ARE WAY TO CONSERVATIVE FOR MY TASTE.[8D]
Old Jan 8, 2008 | 05:18 PM
BONERACIN's Avatar
BONERACIN
Default RE: crane ignition
ANYBODY?
Old Jan 14, 2008 | 04:22 PM
BONERACIN's Avatar
BONERACIN
INSTALLED AND TUNED BY EAR. ADVANCED TILL PING AND THE BACKED OFF!!!
Old Jan 15, 2008 | 06:37 AM
1SG's Avatar
1SG
do a search on this forum about it. Just set it as high as you can, both slope and advanced without any pinging, if it ping at lower rpm,s move the advanced back 1 click, and do the same with the slope at higher rpm's 2500 to max. I set my rpm limit to 6100, but you should keep it under 5800 rpm's
Old Jan 17, 2008 | 07:40 PM
miacycles's Avatar
miacycles
Make sure that the Voes switch is hooked up and the module is set for Normal/VOES not race mode. Voes switch should be set for 7" of vacum. If you need to know how to do this PM me.
Stevo1340
Jun 17, 2019 01:11 PM
traildog
EVO
54
Jul 26, 2014 08:33 AM
Maxdog2
EVO
Apr 7, 2014 09:16 PM
96ApeKing
Apr 28, 2009 12:40 PM
BONERACIN
Jan 8, 2008 05:19 PM
