Prob tuning the Dyna 2000i ignition module
Old Apr 21, 2009 | 12:32 AM
96ApeKing's Avatar
96ApeKing
Default Prob tuning the Dyna 2000i ignition module
Upgraded the pistons on my 96 FLHR (carb) to Wiseco +0.003 and 10.1:1 and the bike was pinging like crazy. All is stock except the Dyna 2000i module.
I opened it up and saw that it was set to curve 4 with VOES in retard mode. (installed at an indy). 6000RPM and dual fire.
Got the manual out and switched off the VOES (since it's only for bikes with turbo) and changed the curve to curve 2 since it's closest to stock.
Now, it doesn't ping but it's really sluggish in 1st and 2nd gear. If I hold the throttle at 2nd gear, the bike would sputter and jerk but once I open it up and increase the revs, this sputtering goes away.
Is this caused because I'm using high comp pistons or is my ignition module screwed. It's only got about 50k on it so I don't think so.
Old Apr 21, 2009 | 07:02 AM
murphdog's Avatar
murphdog
Curve 2 is more aggressive than curve 4. It should ping worse on 2 than on 4. Did you set the static timing?
Old Apr 21, 2009 | 10:39 AM
96ApeKing's Avatar
96ApeKing
Yup set that one according to the instructions sheet. Here's the thing, I adjusted it to curve 1, pick-up is much smoother but there's still some hesitance. The coil has about 130K on it but it was working fine before the high comp pistons went in.
Old Apr 21, 2009 | 05:01 PM
jmetro's Avatar
jmetro
put the voes switch to off,and start with curve 1, and increase the curve number after test riding untill ping is gone.
you might have to adjust your carb too. changing ignition does change fuel usage believe it or not.
Old Apr 21, 2009 | 11:12 PM
Bent Wrench's Avatar
Bent Wrench
VOES is not for turbo, it is like a vacuum advance, it's for part throttle (cruise) speed operation better mileage and response. When you roll it on the vacuum drops and the switch opens retarding the spark to prevent pinging.
Old Apr 22, 2009 | 09:58 AM
96ApeKing's Avatar
96ApeKing
I see, but the instructions advised against VOES stating it was for Turbo / Nitrous applications. Now on curve 1, it still pings but not as much as when it was on curve 4 with VOES on. Curve 2 + VOES off was the best with no pinging at all unless i really lug it but it was sputtering and hesitating in the 1st and 2nd gear.
I'll try the VOES on in curve 1 tomorrow. Is there anyway to check if my coil is good? Spark plugs and cables are new and good. Can it be my carb?
My carb (stock) has a history of overflowing. Every once in awhile it would crank but not start so i'll have to empty the gas from the carb and it'll start right up.
Old Apr 26, 2009 | 04:09 PM
jmetro's Avatar
jmetro
that specific unit uses the switch on the module labeled voes to select wether or not you want the voes always grounded, select off to utilize the voes switch for automatic spark retard at high vacuum.
Old Apr 27, 2009 | 04:11 PM
danfrompa's Avatar
danfrompa
"automatic spark retard at high vacuum." -- Does it have a knock sensor? Just curious how it retards the timing at high vacuum?
Old Apr 28, 2009 | 12:40 PM
jmetro's Avatar
jmetro
The VOES switch. V.O.E.S. =Vacuum Operated Electrical Switch. *correction to my previous post, automatic retard at LOW vacuum (wot, or under load)
Jox818
Feb 3, 2016 04:42 PM
Snydcat
Shovelhead
Jan 29, 2016 10:24 PM
aces&8s
EVO
17
Apr 5, 2014 01:18 PM
wccwilly
May 10, 2009 01:40 PM
hd7574hd
Classic
Aug 26, 2005 07:09 PM
