Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I talked to the tech guy at bub ent. about putting rinehart true duels on an 06 roadglide and he suggested using terry components fuel mgmt system. What I want to know is: does anyone have this on their bike w/rineharts if so how do you like it ? I know you will still have to flash the ecm to increase the rpm to 6200 but thats it.
I don't have one but, from the looks of their ad, this thing will eliminate the need for Dynos and maps. If it works the way it is supposed to it would appear to be the only choice for me.
I don't agree with needing the reflash to raise the limiter. If your engine is stock, there's really no benefeit to spinning it over that high, especially on a "B" engine. JMHO
I picked up my 06 Road Glide in November. I had the dealer install the 103 upgrade with Rinehart Tru-duals. They did their tuning and told me that to get it fine-tuned, I would have to have it done on a dyno. The problem I am having is at 1900-2000 RPM range I have an occasional "cough". It is worse when it is really cold in the mornings. I too talked with a Bub tech and he recommended the Terry closed loop system for my problem also. I have been researching everything I can about this particular system and so far, everything is positive. I am nervously going to order one this week.
Do you have a racetuner now if you do send me an email I can send you 2 or three different maps made for stock 103 with air cleaner / rhineharts. Also need year of your bike so that I can transfer the map to the right format 01-04 or 05/06
