Tuner Question
Old Mar 20, 2008 | 07:26 AM
Jugg's Avatar
Jugg
Default Tuner Question
I,m new to the Fuel injection game and had some questions.I have a stock06 Street Glide and want to put a SE air filter and SE slip ons. I really don't want to get in to the whole dyno thing. Is there a plug and go tuner for that set up?
Thanks
Jugg
Old Mar 20, 2008 | 07:55 AM
DRAGO1's Avatar
DRAGO1
Default RE: Tuner Question
Well,
1. You can have the dealer down load a map for that set up.
2. You can buy a V&H fuel pack
3. Or a cobra fi2000
There many many efi controls out there. It depends on how much you want to spend. And ask your self this do you ever plan on upgradeing your motor like cams or head work or bigger bore etc etc. Because then you might want to spend the money and get a SERT or PC3. These 2 set ups have canned maps for that combo on your bike and you can do it your self with out tuning.
I hope this helps....
FRANK FROM D.B.W
Old Mar 20, 2008 | 10:15 AM
Peppa1's Avatar
Peppa1
I have V/H Oval slip ons, SE A/C and V/H Fuel Pak and my bike runs great. If you aren't going to do any major engine mods I would say the Fuel Pak would be a good buy. Easy to install & program yourself.
Old Mar 20, 2008 | 11:29 AM
Jugg's Avatar
Jugg
I don't planning on doing any motor mods.
Old Mar 20, 2008 | 03:44 PM
Jugg's Avatar
Jugg
If I just do some slipons for know do I need a tuner? Thanks for the help.
jugg
Old Mar 20, 2008 | 04:26 PM
cruiser85257's Avatar
cruiser85257
Jugg,
If you specifically do an SE Air Kit and SE Slip Ons, then the simplest thing to do is to have the Dealer give you the HD Stage one download. They just hook up to your ECM and flash it with a new Map designed exclusively for that setup.
Stage One Flash=$150.00
Depending on dealer they may or may not charge you the 1/2 hour Labor.
Old Mar 20, 2008 | 10:19 PM
Bertk's Avatar
Bertk
ORIGINAL: Jugg
jugg
If all you want to do is slip-on's, read this post.
https://www.hdforums.com/fb.asp?m=3059741
Old Mar 21, 2008 | 12:29 PM
Jugg's Avatar
Jugg
Mine does not have o2's.
scooter_nate
Apr 18, 2014 01:15 PM
willie37
Feb 2, 2013 11:33 AM
tht1124
Exhaust System Topics
May 20, 2009 08:33 AM
128auto
Jun 28, 2008 08:33 AM
Phins74
May 6, 2007 07:05 PM
