PCIII Map Needed
Old Apr 23, 2008 | 05:34 AM
maineultraclassic's Avatar
maineultraclassic
Default PCIII Map Needed
I'm doing a motor build for a local, and I need a PCIIIusb map to get him going after we are done.
Here is the build -
'07 Street Bob
PCIIIusb
stock ecm
103" with SE flattop pistons
Big Boyz Heads with 1.9" intake valves
10-1 CR
Woods TW6-6 cams
SE air cleaner
V&H Big Radius
If anyone has a map for this build or something close, please email me at maineultraclassic@maine.rr.com or post it here.
Thanks,
Steve
Old Apr 24, 2008 | 08:46 PM
maineultraclassic
Default RE: PCIII Map Needed
bump
Old Apr 25, 2008 | 07:45 PM
wallyn's Avatar
wallyn
Not sure what you are looking for but this should at least get you close. This was available on the Dynojet Download site.
M814-019
*Advanced Map* Bub 7 2:2 Exhaust Screamin' Eagle 103" flat top pistons Screamin' Eagle 255 Cams Screamin' Eagle air filter Stock ECM Rev Xtend enabled Fuel table 1 is rear cylinder
Looks like it is close and should at least get you in the ballpark until you get it dynoed. Looks like a twin table fuel set up.
Good luck
Old Apr 27, 2008 | 01:16 PM
maineultraclassic
It's very hard to find a map for a particular build, and even harder when it's a "custom" build.
I was hoping someone would have a map for a build very close to this one, it's a common build with the 103" and the Woods Cam, it's the headwork that is hard to nail down.
Steve
Old Apr 27, 2008 | 06:46 PM
wallyn's Avatar
wallyn
If you are doing a lot of your engine building you should invest in a Wide Band sensor system so you can adjust the fuel controller yourself. Daytona Twin tec's 02 sensor on their website shows how do mount the sensor temporarily. I am sure you could do that with any of the systems out there.
With that you could load a map that is close and then ride the bike and record the sensor readings and the adjust the map accordingly.
The Horsepower tweakers on the Vrod forums have created a spreadsheet that takes your 02 readings and creats a new table from your old table values.
Even if someone has a build similar to yours you would still need to dyno it or take your on 02 readings to get the most out of the build.
Old May 4, 2008 | 07:55 AM
maineultraclassic
Parts are in for this build, and we still don't have a map for the PC.
Other then the DJ website, which has nothing to offer for this build..............anyone have anything?
Steve
Old May 6, 2008 | 05:34 AM
maineultraclassic
bump
Old May 8, 2008 | 05:33 AM
maineultraclassic
bump
harley7316
Oct 26, 2013 11:00 PM
Frisco73
Aug 18, 2012 10:09 PM
maineultraclassic
May 8, 2008 05:33 AM
Mordrapheus
Jul 3, 2007 08:11 AM
srob
May 9, 2007 09:35 PM
