Electrical Problem
Old May 7, 2008 | 09:05 PM
ricky4453's Avatar
ricky4453
Stage II
Default Electrical Problem
I have a 2002 Softail Heritage Classic. My running lights on each side of the tail light continually burns out bulbs.I replace them and within a few days they are out again.Can anyone offer a possible solution? I have had it looked at twice at the Harley dealer and they say nothing is wrong.
Old May 7, 2008 | 09:25 PM
rjrivero's Avatar
rjrivero
Default RE: Electrical Problem
Ricky,
They aren't running lights. They are turn signals only. They can be used as running lights if you use the Run/Stop/Turn module from HD. Part Number: 69461-06A
Otherwise, they'll only light up as turn signals.
Old May 7, 2008 | 10:32 PM
ricky4453's Avatar
ricky4453
Stage II
Thank you for the feedback. I guess what confuses me is when I replace the bulb they work as running lights for a few days. With that said, I have to believe that the part you are speaking of is on my bike.Additionally, the front turn signals work a running lights and they are working fine. The electrical diagnostics from the dealer show there are no problems. Frustrating...
Old May 7, 2008 | 10:45 PM
wallyn's Avatar
wallyn
The Front turn signals actually are running lights. You may have the the wrong bulbs in the rear turn signals.
Old May 8, 2008 | 09:34 PM
rjrivero's Avatar
rjrivero
ORIGINAL: ricky4453
If you do have the module, then you need to have it checked. If your rear turn signals have RED lenses, then they should have put one in for you.
I believe the early ones did not have running lights. The running lights came about in 2004-2005. I think.
Check the module.
bunotz
Nov 6, 2013 09:15 PM
paul987
May 2, 2011 05:26 AM
DitchDigger
Oct 14, 2010 10:58 AM
NCCopBikeRider
Jan 25, 2009 02:07 PM
saltlick
Jan 30, 2007 11:38 AM
