HELP 08 FXD codes
Old May 12, 2008 | 11:43 AM
maddcatt's Avatar
maddcatt
6th Gear
Default HELP 08 FXD codes
I have a code popping up that says "no rsp"..The bike randomly starts and thens quits after about 10 seconds..Finaly it will run,but speedo might quit going down the road,and my bus er message constantly pops on the milage window and the check egine light and the key fob and battery light are iluminated..
I have had 2 shops look at this problem,which I will probly take it back to.
The shop tried to jump to the idea that my higher handlebars were tugging on mywire cables going to my switchs,so they only spent about 15 minuts and told me they fixed it and advised me to put my stock bars back on...
As soon as I got the bike home after the second start the bus er came on and I have been lost ever since trying to figure out the problem.
One fellow suggested in the forum that his ignition switch was causing the problem,and after replacing the switch,everything was normal.
I am wondering about the ecm being goofy,like a PC with a virus.
I have some computer machine experience and most of the time the switch is a input to the ECM and like a bulb wold be an output..
I am trying to find a 08 electrical diagram,so I can check the terminations myself.
Old May 12, 2008 | 12:24 PM
Lone Watie's Avatar
Lone Watie
Default RE: HELP 08 FXD codes
pm me your email address and I'll see what I can do for you.
"Bus ER" according to my elec. diag. manual indicates a 'serial data bus shorted low/open/high' your dealer may not be too far off track if something is tugging on the wire, or wire got pinched during your install of the h-bars. I'm not a mechanic with these things, but check out the connections going into your speedo on the handlebars (FXD right?). Are you getting any other DTC's? I'm looking for the method to check DTCs with the speedo. Send me as much info as possible, and I'll do what I can as far as referencing my book; like I said, though, I'm not a mechanic, just a guy like you who likes to try to fix stuff myself before paying someone.
Watie
Old May 12, 2008 | 06:56 PM
Skivvy9r's Avatar
Skivvy9r
HD offers an electrical diagnostics manual for your year/model. They're as valuable as the service manual when maintaining your own bike,
Old May 12, 2008 | 07:10 PM
maddcatt's Avatar
maddcatt
6th Gear
Thanks for your help my EMail is b_b_roadking@yahoo.comI will keep you informed of my progress thru E-Mail
Larry
Old May 12, 2008 | 07:27 PM
Lone Watie's Avatar
Lone Watie
email sent...
ORIGINAL: maddcatt
Larry
PROVIDER7
Jan 27, 2018 08:28 AM
Ybnormal67
Aug 13, 2014 10:23 AM
bufbills
Jun 2, 2013 07:38 PM
rwjjr
May 26, 2007 04:10 AM
2001 softail
Apr 27, 2007 09:28 PM
