Help need map for tmax
Old May 24, 2008 | 05:36 PM
thumper05's Avatar
thumper05
Default Help need map for tmax
I dowlloaded what i thoufgt was a close mix for my 05 stock motor ultra,
d&d fatcat pipes and hi flow air filter
im getting crappy 31 mpg...what is a good map for the mix?
Old May 25, 2008 | 05:16 AM
shovel52's Avatar
shovel52
Default RE: Help need map for tmax
I am at the wrong computer right now to see the Thundermax stuff. A quick call to them will net you pretty fast results. They seem real friendly. I put the Tmax on my Deuce about three weeks ago. It runs better everytime I take it out. Mine is getting in the high thirties around town, but I don't ride it hard. Where are you getting thirty and how hard are you riding? Did you look at the graphing and check the AFR? I think mine is about 13.5 across the range. I will get out there and fire up the other computer and see what is there. God, there are 500 or more maps.Good luck. Ken
Old May 25, 2008 | 03:37 PM
rbabos's Avatar
rbabos
Looking ata few of the 88ci maps it would appear that most are set at 13 afr across the board. Good for power, not so good for economy. Editing the throttle open positions where you spend most of the time cruising would probably give much increased economy. Go with around 14.2 in these areas only and leave the rest above and below as is.
Ron
Smoked~black16v
Milwaukee Eight (M8)
16
Jun 11, 2019 07:14 AM
chi45cken
Aug 1, 2014 03:37 PM
508DieHard
May 31, 2011 09:58 PM
tunaman
Aug 7, 2008 09:10 AM
thumper05
May 24, 2008 11:32 PM
