Need a code explained
Old Jun 1, 2008 | 08:14 PM
elpoman's Avatar
elpoman
Default Need a code explained
I have an O8 ultra, and just checked my diagnostic trouble codes, and I get a code that is not on any list that I have seen. I get a C 1095 on the laster letter on the dash witch is a small letter b witch is also not shown on any list. I have PSSPTb. Help.No check engine light.
Old Jun 1, 2008 | 08:55 PM
waterboyjack's Avatar
waterboyjack
Default RE: Need a code explained
DTC 1095= Front brake switch open. check little black switch behind brake lever.
Old Jun 1, 2008 | 09:08 PM
elpoman's Avatar
elpoman
ORIGINAL: waterboyjack
I'm new to Harleys, and what little black switch, and where behind the brake lever.
Old Jun 1, 2008 | 09:10 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
I was searching my manual...Where did you find that code Jack??
Old Jun 1, 2008 | 09:14 PM
elpoman's Avatar
elpoman
It came up on the b letter of the PSSpTb. the b is not listed on any code list that I can find so far. it was a C 1095 code.
Old Jun 1, 2008 | 09:16 PM
elpoman's Avatar
elpoman
All the code lists that I have seen have codes for the PSSPT but not the b. I'm tring to find out if it is something to take it back to the dealer about, or just clear and see.No chech enging light.
Old Jun 1, 2008 | 10:17 PM
waterboyjack
it is in the electrical diagnostic manual. switch is located near pivot point of lever "inside" right hand control housing.
Old Jun 1, 2008 | 10:34 PM
waterboyjack
this dtc is for ABS. according to manual ABS will still function fine however you may not have brake lights when applying front brake and YES , I would take it back to dealer if it did not clear after checking switch in hand control/front brake lever. Manual says can be caused by open circuit or short to ground. Have you had the switch box off lately??? pinched a wire maybe when reinstalling??? Sorry it took so long to respond, hope this helps.
Old Jun 1, 2008 | 10:42 PM
gs34doc's Avatar
gs34doc
Thanks Jack. That explains why I couldn't find it. I was looking in my 07 manual.
Old Jun 1, 2008 | 10:47 PM
waterboyjack
ORIGINAL: gs34doc
Service manuals are OK..... But Much better if U have Parts book and Electrical diagnostic manual. My 2 pennies.
