03 Ultra Classic with no spark
Old Jun 16, 2008 | 10:10 PM
DAGWOOD3882's Avatar
DAGWOOD3882
Default 03 Ultra Classic with no spark
Alright, I need some help from some of you technical guys out there....I rode my ultra about 200 miles saturday with no problems at all , came home and parked in the garage......got up to go to work today and wouldnt start...after further investigation I found no spark.....pulled the ignition coil off and ohmed it out according to the repair manual and everything checks out ok.....the 12v wire going to the coil is hot with the switch on, but i dont get any reading on the other 3 wires in the electrical plug going to the coil....It appears to me that the ecm could be bad, but Im looking for any other options before replacing the high priced ecm.....any help would be appreciated....thanks
Old Jun 16, 2008 | 10:54 PM
Doc 1's Avatar
Doc 1
Default RE: 03 Ultra Classic with no spark
How did you test the spark to determine it didn't have spark?
Old Jun 16, 2008 | 11:09 PM
DAGWOOD3882
with a spark tester
Old Jun 16, 2008 | 11:31 PM
Doc 1's Avatar
Doc 1
Where the plugs in the head or removed?
Old Jun 17, 2008 | 05:30 PM
DAGWOOD3882
checked it both ways....took it to my local indy today and he hooked it up to the scanner and it looks to be a crankshaft position sensor.....hope he is right
Old Jun 17, 2008 | 06:36 PM
Doc 1's Avatar
Doc 1
CKP is what I was getting at...good luck
Old Jun 17, 2008 | 06:42 PM
littlet's Avatar
littlet
quick check on a bagger for a bad ckp is to crank the bike and if there is no increase on the rpms then there is no ac signal
Old Jun 17, 2008 | 10:18 PM
DAGWOOD3882
Thanks for the help guys!!!!!
Shackleford
Aug 21, 2014 08:51 PM
lagunatic
Shovelhead
Jul 16, 2011 09:16 AM
pryoratp
Oct 14, 2010 04:41 PM
av8or
Jul 6, 2010 10:40 PM
handy444man
Jan 2, 2008 07:44 PM
