Diagnostic Codes
Old Aug 20, 2008 | 07:18 PM
lvspringer's Avatar
lvspringer
Default Diagnostic Codes
Hello,
I have a 2006 FLSTSC-I and have spent the past several months customizing it but am now having some problems that I attribute to my lack of ability in wiring. I added longer, wider handlebars so had to replace the handlebar switches on both sides. I used the appropriatre Deustch connectors and crimp tool and followed the wire color coding. I also added passing lamps and the retro style horn. I relocated the front turn signals and re-wired both front and rear.
I am running the diagnostics and come up with the following information:
P (Electronic Ignition) No Response
S (Turn Signal Security Monitor) Code 61121 and then the word "END" and then it flashes PN 68923-00d
SP (Speedometer) None and then it flashes PN 67033-04A
T (Tachometer) No Response
Even though my turn signals so not appear to be working correctly, they do flash appropriately when I arm and disarm the security system. Since I removed the battery, I also used the master reset (On-Off-On-Off-On and pressed the left turn signal and got the expected flashes. However, my red security system "Key" icon remains lighted.
I've got nothing when I hit the starter so I think the security system is still set to on.
Any ideas and help would be greatly appreciated. I've been working on this custom for months now and want to ride
Old Apr 25, 2025 | 02:04 PM
Smikeybawlsnm's Avatar
Smikeybawlsnm
Stage I
Default Same codes but bought used without a key fob
I'm wondering what to do. If you don't own a key fob, I'm having the same error codes come up on my hardly 883 2007 sportster. I keep getting the same answer in Google. Also Tried resetting the security system by verifying the pin, entering it, but I couldn't verify the pin.So I entered the last five of my vin and that didn't work and I entered 22222 and that didn't work any suggestions
Old Apr 25, 2025 | 04:12 PM
rigidthumper's Avatar
rigidthumper
No Resp means the wiring to the run/stop switch isn't where it's supposed to be, or the fuses are blown. Check fuses first.
Old Apr 28, 2025 | 09:42 PM
paulmedford's Avatar
paulmedford
also something on the data line, or the data line not connected, it can also cause a bus er
bezoar
May 15, 2022 05:53 PM
Mr. Mike
May 28, 2015 09:10 AM
vanceandharley
Electrical/Lighting/Alarm
Jan 18, 2015 02:48 PM
justmealwatts
Apr 6, 2013 12:28 PM
davidsdad
Sep 3, 2011 05:30 PM
