intermittent loss of ignition
Old Mar 25, 2006 | 10:32 AM
spurlen's Avatar
spurlen
Stage II
Default intermittent loss of ignition
2000 Softail. From a cold start (doesn't matter what ambient temp is) I get appr., 10 minutes run time whether it's at a idle are going down the hi-way. Then it just dies as if the ignition has been turned off. After it has set several minutes (5 at least) It will crank back up, but will only run for a few minutes and dies again with same time frame before being able to restart it. I have checked to confirm that it is dieing due to loss of ignition fire. I have replaced the coil and the ignition module, and nothing has changed. I have no problem getting it into a shop, just havn,t been able to find anyone from a dealer standpoint willing to give any info on what the problem really could be. Are what kind of diagnostics they will use to find the problem. I don't see it as being a bad electrical connection, because it is very consistent on the time frames. The entire charging system was R/R placed several years ago and seems to be fine, since the battery never needs to be charged. This can't be the only 2000 model that has done this.
thanks: spurlen
Old Mar 25, 2006 | 10:56 AM
FLHSbob's Avatar
FLHSbob
Default RE: intermittent loss of ignition
Not to overlook the simplest solution. Last fall on a trip to York Pa. my 92 FLHS started quiting (shut dow) intermittingly. The service guy at the York HD dealer looked it over, installed star washers on the battery teminal bolts and problem gone.
Just a thought.
Bob
Old Mar 25, 2006 | 01:21 PM
Harley Greg's Avatar
Harley Greg
Same here after I put in a new Battery. Battery bolts loosen up and will start arching. took me 3 visits to the shop to figure it out.
Old Mar 29, 2006 | 09:17 AM
FLHSbob's Avatar
FLHSbob
Spur
How did this turn out. Did you get the problem solved?
Bob
Old Apr 4, 2006 | 10:17 PM
spurlen's Avatar
spurlen
Stage II
April 4th 2006. I was the crank sensor that mounts in the cam cover.
CJHD
Jul 18, 2019 11:09 AM
Bulldozer25
May 11, 2013 02:05 PM
clove07
Shovelhead
17
Aug 17, 2009 11:41 PM
jeffm1
Shovelhead
Aug 9, 2009 06:11 PM
ironhead73
Aug 1, 2006 12:48 AM
