headlight help
Old Mar 26, 2005 | 10:51 PM
goodliving1's Avatar
goodliving1
Stage IV
Default headlight help
I have a 2003 Road King and want to change out the headlight. How do I get the front trim ring off? I took out the sheet metal screw at the bottom of the ring and now all it does is spin. What's the trick? Thanks
Old Mar 26, 2005 | 10:56 PM
nmfxstc's Avatar
nmfxstc
Default RE: headlight help
It most likely has a small metal tab that is inserted into a slot on the inner housing at 12 o'clock...try lifting the ring from its normal position and that should do it (same as my Ultra)
Old Mar 26, 2005 | 10:57 PM
igniter's Avatar
igniter
Go look at your last thread.
Old Mar 26, 2005 | 11:09 PM
rdking's Avatar
rdking
With my '05 Road King Classic I just gave it a tug at the bottom and it popped right off (after removing the screw).
Tom
Old Mar 26, 2005 | 11:26 PM
goodliving1
Stage IV
Thanks to all. That got it. I just thought I was going to screw something up by pulling on it like that.
Old Mar 26, 2005 | 11:59 PM
hawk's Avatar
hawk
What he said
ORIGINAL: rdking
Tom
Old Mar 28, 2005 | 03:29 AM
investorsc's Avatar
investorsc
Did you go to a brighter bulb or what?
BRUCE
rocktoy
Jan 21, 2016 07:46 PM
hack333
Oct 12, 2015 05:19 PM
terrysillik
Apr 21, 2011 04:53 AM
Mr5150
Apr 23, 2007 06:59 AM
TheVaGambler
Aug 12, 2005 03:54 AM
