Headlight trim piece
Old Aug 1, 2009 | 01:29 PM
hack333's Avatar
hack333
1st Gear
Default Headlight trim piece
While taking off the long slender trim piece on the top of my headlight the screw busted. anyone know what this piece is called?
Old Aug 1, 2009 | 02:21 PM
im's Avatar
im
limited info.
Bike and year?... is it a road king nacelle..the spear?
screw?
very limited iformation for those that can not see the bike.
Taking a guess:
road king top trim piece on headlight nacelle (spear) has one screw/bolt and other end has thread cutting nut. If caution is not taken the thread cutting nut will break nipple it is screwed to easily.
Possible solutions:
if enough of nipple remains use different nut.
or use #3M brand double side tape tape (in red roll) to hold spear onto headlight. It will hold up to a few lbs. and that piece weighs nothing...or replace.
Old Aug 1, 2009 | 02:31 PM
hack333's Avatar
hack333
1st Gear
[My bad I didn't realize how vague that was till I read it again... I have an 03 Road king not sure what a nacelle is. Here is a pic of the part.
Old Aug 2, 2009 | 03:23 PM
im's Avatar
im
yes that is the part i guessed.
The nacelle is the common name for entire metal housing for headlight.
The common name for your part(picture) is the spear.
not an uncommon part to have the tip broken off.
you can try the #3M brand foam double side tape available at lowes or home depot and just place some under the spear or purchase a new spear..consider ebay.
Old Aug 2, 2009 | 03:25 PM
im's Avatar
im
this link is to bike bandit and is a good aid to visualize parts..just follows steps for year, model and area of need.
http://www.bikebandit.com/harley-dav...arts/oem-parts
Old Aug 2, 2009 | 04:25 PM
skratch's Avatar
skratch
actually, it has the one thread cutting nut, the screw/bolt is actually part of the headlight riser cover which has a notch in it and the spear has a tab that fits into that notch.
p/n: 67868-03. runs less than $20.00 from zanotti's.
Old Aug 3, 2009 | 04:42 PM
hack333's Avatar
hack333
1st Gear
thanks to all for the helpful replies got a new part from my local HD dealer and am back on the road.
Ryan
Old Aug 17, 2012 | 02:23 PM
Hannibal19xx's Avatar
Hannibal19xx
Stage I
Is it the correct part number for my 2002 road King?
thanks and have a nice day!
Best regards from germany
dennis
Old Oct 12, 2015 | 05:08 PM
cecilonce's Avatar
cecilonce
Stage III
Hi all. Got a new part like this (67899-04) and notice the 'bolt' that goes into the nacelle isn't threaded. I saw Skratch said it had one single thread cutting nut. Anyone know the PN for that or where I can get one easy.
Thanks.
Old Oct 12, 2015 | 05:19 PM
GTK's Avatar
GTK
Take the part and go to your local hardware store.They will probably have the self threading speed nut you need.
civilbob
Jul 9, 2013 09:59 PM
terrysillik
Apr 21, 2011 04:53 AM
DrPlastic
Feb 6, 2010 06:56 PM
TheVaGambler
Aug 12, 2005 03:54 AM
goodliving1
Mar 28, 2005 03:29 AM
