Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I had HID in my BMW and all that was required was to find room for the ballast. My RT had horrible lighting and needed a lot of help. I hate driving at night but, sometimes you must. I believe these RoadKings would have enough room in the headlamp housing to hold the ballast. HID's only pull about 35 watts and the wiring is made to handle 55 watts. You need a bixenon kit like this in order to still have low/high beam. I still have a spare kit and I haven't decided whether to try installing it in the R-K or sell it. I find the lighting on my stock R-K to be very good. I would hesitate using a high wattage bulb due to overheating wires along with possible melting of housing components. Hope that helps.
The too high current and associated overheating is why I stopped with the 100/80 watt German Rally Bulb. It is compatible with stock wiring and socket material. They make a 130/100 that requires the use of a metal socket vice a plastic one. The 100/80 is very bright. It does a good job for me, especially considering I don't have the running/passing lights. Too much chrome, y'know!
Light is a wonderful thing to have at night just ask any body that's spent any time riding an old Brit bike.
(when the Lord said let there be darkness Lucas Electric was born) Ive used 100/55 H4 off road 0n my last 3 bikes and I don't think Id ever ride with out one again. They are good and brite when you need it then drop it down to low beam and you don't bother any one
J.B.
Who makes those bulbs? Is that a standard designation?
The last one I got was from J&P and goes by Super Osram H4 halogen part# is 3100271 for the 55/100 and it goes for about $10 and I know I got one from USA TWIN also. It sure make's it a lot better for running at night.
J.B.
Great, I'm ordering one of those puppies!! Maybe if Clammy puts one in and points his bike south and I put one in and point north we will see each other.... Clammy, you ordered a skull tail light yet?
David
i love to pull up behind those little jap low riders with my spots on and whatch lite come out of every crack of his car!! hey what can i say when your in your fifties, it takes less to entertain yourslef!!
J.B.
Will the factory wiring and ballast handle this bulb? Did you put them in the passing bulbs as well?
