Brightest bulbs?
Old Mar 28, 2005 | 10:59 AM
Lovetoride's Avatar
Lovetoride
Default Brightest bulbs?
I passed a guy on the road yesterday that had the brightest bulbs I've ever seen. It made his Harley almost impossible to miss. I think this would be a safety advantage as well as being very cool. It looked like a Heritage or another big bike. It had a factory light bar. All three were crazy bright and seem to have a slight blue tint to them. Has anyone changed there bulbs? Can they support Zenon bulbs? I have an 05 Heritage...
Thanks,
Ryan
Old Mar 28, 2005 | 12:10 PM
hawk's Avatar
hawk
Default RE: Brightest bulbs?
I have seen those too and I hope someone has them so we can find out about them
Old Mar 28, 2005 | 01:59 PM
Retired_Ted's Avatar
Retired_Ted
There has been a lot of talk about "brighter" bulbs on the BMW forum I check into. Some guy actually did a scientific test using a light meter and other equipment and found that the tinted variety might actually look pretty neat, but, gave off less light. Anytime you filter the light, it'll have less lumens. The gov't limits the wattage of our headlamps to 55 watts and the wiring that supplies the lamp will only support that plus a little. HID lighting works much better and only pulls 35 watts due to the way light is generated (an electric arc). However, unless you want to install HID, we should probably stick with the factory halogen bulb. The real advance in lighting has come from the re-designed reflectors that concentrate the available light where we need it. I burn all lighting during the day from the passing lights as well as the headlamp. We could also install more auxillary lighting on the crash bars. But, I wouldn't buy those expensive replacement lamps that have the tint - a lot of hype imho.
Old Mar 28, 2005 | 02:19 PM
Pelonz's Avatar
Pelonz
I run a headlite modulator on my low beam. Visually effective as now when splitting lanes out here traffic tends to move asside
Old Mar 28, 2005 | 03:10 PM
AceArt's Avatar
AceArt
When I ordered my Super Glide, I had the auxialiary light kit put on (labor free w/ the new bike). I was leaning toward the dark smoke for the auxialiary bulbs, gut the parts guy told me that they actually looked more greenish than smoke, so I went ahead and ordered the halogen bulbs. With the new halogen headlight and these bulbs. it should be bright! I'll let you know.
Old Mar 28, 2005 | 07:14 PM
grumpygit's Avatar
grumpygit
I dunno about bright - it seems OK, but you can fry eggs on my headlight. []
Is it normal for them to get so hot? I worry about things melting in there!
Old Mar 28, 2005 | 07:43 PM
Pelonz's Avatar
Pelonz
ORIGINAL: grumpygit
Never noticed mine getting that hot......overeasy please
Old Mar 28, 2005 | 07:52 PM
Retired_Ted
Halogen bulbs operate at very high temperatures - the idea being that as the filament evaporates, the glass envelope will be too hot for the tungsten to condense on it, and, with the help of iodine or some other halogen, the tungsten vapor will find its way back to the filament and "heal" the area from which it came. That way, you'll never notice a blacking of a halogen bulb as you would in a normal light bulb. The brightness stays almost constant over the life of the bulb. Pretty neat, huh?
Old Mar 28, 2005 | 10:24 PM
Lovetoride's Avatar
Lovetoride
ORIGINAL: Retired_Ted
Hey Ted!
How big of a hassle is it to change to HID or to jump to the 110 watt European set-ups? I rarely ride at night because my lights suck. I would love to make them much brighter...
Thanks,
Ryan
Old Mar 28, 2005 | 10:38 PM
pococj's Avatar
pococj
ORIGINAL: Lovetoride
Hey Ted!
Thanks,
Ryan
I run a German Rally Bulb in a custom headlight on my Sloptail. It is 100w/80w. Yeah, it's illegal, but then I haven't had any idjits pull out on me since I installed it. Got it from J&P, part no. 380-887.
They also have PIAA H4 bulbs that are similar in light output to HID lamps, but use less power.
