Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
According to my GPS, my speedometer shows that I am going 2-3 mph faster than what I am actually going. I'm sure that's OK, but I'm **** about accuracy, and I (apparently) can change it so I want to.
I don't need all the complexity of the VSS calculator with a 'tire rollout estimator' and all, I just want to know how much, and in which direction, to change the number in that pop-up window.
I do not know the answer for you but getting the tire roll out is plenty simple to do. Place a mark on the tire where it meets the ground and mark the ground as well. Now sit on the bike and roll it straight forward until the mark on the tire meets the ground again. Transfer the mark onto the ground then measure between your two marks with a tape measure.
Yeah, that's what I do. But I also go several revolutions and divide the resultant length by that number. Where the mark is closest to being at the ground is somewhat discretionary. By adding some revolutions you can minimize the "discretionary" effect for a truer reading.
Start by increasing the number by about 50 to correct your speedo being 3 mph slow. Took me about 3 attemps, guessing and using my gps to get my speedo spot on.
Doing more than one time around on the tire does help with the error factor. We find that twice around seems to be all you need but once is good enough for most people.
Just my opinion, but I wouldn't use a GPS to gauge the accuracy of your speedo. Most non-military GPS units are only accurate to between 9 and 30 feet. Not close enough to determine if speedo is off 3-4 mph.
I add this final post in case someone searches for this topic sometime. The magic number for me turned out to be 2130. Actually I started by adding 50 (as Old Fart suggested) to the original 2078, which resulted in 2128. It turned out to be less than 1/2 mph off in the original direction so rounding it up to 2130 seemed like the right thing to do.
Actually, the algorithm used to calculate speed is a bit different then the one used for location. Speed is really close (assuming good satellite reception).
But you are correct, location accuracy is skewed intentionally.
