TTS Master Tune ?
Old Jul 19, 2009 | 01:59 PM
iclick's Avatar
iclick
Originally Posted by Dalton
I have run the PCIII on a 95" build that was just fine, but once you start getting into the bigger builds, or bigger cams where there is a need for a large change to the timing tables, you need to go to the next level, SERT, SEST, TTS etc.
PCIII gives ±10° of advance settings in 250 areas of the RPM/TP chart. Not sure about PCV, but it may be more, as the AFR range on it jumped from ±100% to -100/+250%.
There are autotune systems out there, but they too are not truly autotune, you still need to make tweaks to maps. Nothing beats a dyno but you can get close.
PCV-AT is true auto-tune for the AFR but not ignition timing tables, which is much easier to tune properly.
IMO the best bang-for-the-buck is a PCV from Fuel Moto, which will get you into a tuner with an accurate map for $300, and a dyno-tune is not required for most hardware configurations. Search "Fuel Moto" in the Touring section of this forum for more feedback on their products and service.
Old Jul 20, 2009 | 09:36 PM
gli.der's Avatar
gli.der
Originally Posted by Hogflash
If you have not changed anything and the popping has just now started, look for an air leak in the exhaust. If it has always been popping, you can correct this with the TTS by modifying the map that is currently installed (the person who tuned the bike should have given you a copy of this). Download the tuning guide from the TTS mastertune site for complete instructions on how to eliminate the popping, but usually you need to richen the AFR 5-10 percent in the 0% TPS region between 1500 to 3000 RPM. http://www.mastertune.net/files/calibrations.asp
--Gary
Thx Gary, I just resealed my mufflers and tightened the head pipes. If that doesn't take care of it, I will check with my tuner.......and TTS website.
Old Jul 29, 2009 | 10:36 PM
sjtman's Avatar
sjtman
1st Gear
Default TTS Question for Wurk Truk
Ordered a TTS today .... reading the manual but haven't had that "aha moment".
I think I'm ok on the set up and running the vtune etc. What confuses me is the CLB and VFR tables. If I set the CLB table to say ... 758 I would get a AFR of 14.55 after running the Vtune set up. What if I wanted to run 13.5 AFR? The CLB values are above the recommended maximum of 800. Do I just go to the AFR Table and select 13.5 AFR after doing the Vtune?
Hope I'm not to vague as these CLB's and AFR tables are a little confusing!
TKS
Old Jul 30, 2009 | 08:26 AM
jpbo's Avatar
jpbo
Thumbs up
Tuning yourself with the tts is not so easy. but like i did,i bought from Doc a reliable tuner
who stand behind is product, you have to follow carfully the tuning guide to acheive a good tune for your bike, after that, i sent the final map to Doc,he tweaked the values to create the final map for me. Now my bike is running great
Warning, buy from someone who will help you if you need and be ready it got lot of time
Old May 31, 2020 | 04:44 PM
Marco Shaw's Avatar
Marco Shaw
1st Gear
Default this marco
i have a master tune 2 p/n 2000008. what hardware do i need so i can tune my Bike
Old May 31, 2020 | 05:53 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Depending on year and model you will need one of two cable kits. If your bike has a 4 or 6 pin DTC is what your looking for to get the correct set of cables. Other than that the software is downloaded from
http://www.mastertune.net/downloads_...re_updater.php
Follow the direction on the screen and you will be set.
Old May 31, 2020 | 09:54 PM
Marco Shaw's Avatar
Marco Shaw
1st Gear
Default Tts
thank you for the come back. It was the answer I was looking for.
niteglide
Jun 2, 2020 09:21 PM
kuxika
Sep 27, 2009 11:44 AM
johnsonabq
Jul 6, 2008 02:29 PM
UltraKla$$ic
Feb 24, 2008 07:56 AM
KBFXDLI
Nov 24, 2006 03:37 AM
