PCIII USB setup
Old Apr 19, 2009 | 08:22 AM
Jessie's Avatar
Jessie
Question PCIII USB setup
Hi Guy's I installed my power commander with the fuelmoto map what else should I do such as throttle setting ext ?
Old Apr 19, 2009 | 08:52 AM
jmetro's Avatar
jmetro
set the throttle position, and with everything hooked up, press cntrl +f, and select extend redline, if you were at a dealership i would say reset afv to zero, but you can only do that with a digital tech, so the next time you stop in for an oil change or what have you, have them do that for you (should be free) just skip that if you have it dyno tuned.
Old Apr 19, 2009 | 10:38 AM
Jessie's Avatar
Jessie
what do I set the throttle at ? do I need to do anything else ?
creekhed1
Aug 1, 2008 02:59 PM
FLHTS
Jun 24, 2008 05:38 PM
shagnasty
Feb 21, 2008 05:57 PM
nada1
Mar 12, 2007 09:17 PM
bob53
Sep 21, 2006 11:51 PM
