ditching EFI..
Old May 18, 2009 | 10:27 PM
low_ball's Avatar
low_ball
got a stage I screamin eagle hi-flow air cleaner, k&n filter.. (200$+ down the drain).. torqued to spec man! if i would have changed it over to a carb in the first place.. i would've saved myself almost 1K in un-necessary parts..
Old May 20, 2009 | 07:01 AM
low_ball's Avatar
low_ball
Originally Posted by Hammer107
Either the setting is wrong or that is a defective Fuel Pak.
How does it run without the Fuel Pak at all? Do you have an Air Cleaner too or just pipes?>
w/out the fuel pak.. there's more backfiring.. with the fuel pak there's a little less backfire but the backpressure @ highway speeds sounds like air brakes on a big rig..
Old May 20, 2009 | 07:03 AM
low_ball's Avatar
low_ball
also, i have a stage one air cleaner on it..
JAMIECONYERS
General Topics/Tech Tips
Feb 10, 2021 01:04 AM
66LOW
Nov 23, 2011 03:47 AM
JustDave71
Aug 7, 2011 07:50 AM
moonshined
Feb 7, 2011 01:36 AM
MJHJEA
Aug 22, 2010 07:22 PM
