Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a pair of braided chrome plug wires that I wanted to install on my 06 Road King Custom. The Harley dealer told me not to have them installed because I would have trouble with the wires shorting and arking. Has anyone had this problem? The Brand is Magnum and they are Sterling Chromite II
The factory ignition system carries not only the main power to ignite the plugs, but also carries a constant 80 volts to be used as a sensor for the ECM to validate the complete and thorough combustion....
It's called ION Sense....
Any modifications to the Ignition Coil Secondary system (Aftermarket Plug Wires or Plugs) normally result in a CEL (Check Engine Light) and arcing/burning of wire sheathing....
