1998 FSXTC Starting issue
Bear with me, I am a newbie here. I have some pretty good mechanical skills, built a couple of cars up, but never really did engine work. I know my way around things, and have been learning the terminology specific to the H-D world. I will try to be as thorough as possible in my explanation. Last season I went to start the bike up, and all I got was a "whirrr" sound. Since it was late in the season, I was holding off until this season to tackle it. I determined (easily) that the pinion gear was not engaging with the ring gear and therefore not turning the motor over. The starter was in fact turning, hence my whirr. I replaced the battery, it was the original from factory and after 8 years of service, I know that I was pushing it. Still got my whirr, only faster now. Last night I tested the starter relay, full continuity when energized. I began taking stuff apart (I am being simplistic here). Primary cover drained and off, ring gear pristine, pinion gear pristine, some resistance when manually pulling it out. Pulled off rear exhaust pipe, and jackshaft bolt so that I could remove the starter and bench test it, dang when they say sparks fly.. they are not kidding, anyhow.. I only got through the first test last night being it was so late.. but when checking the solenoid kick out, it kicked out HARD. I will perform the other 2 tests to check hold out and return, but my concern now is my jackshaft. Since I have never seen a good clean one, I think the splines are a bit worn on it (starter side) but am not sure. I have attached the best photo I could grab last night, I am looking for any and all possible routes to go with this.. any help is greatly appreciated, TIA.
[IMG]local://upfiles/13704/730F6D5A0FD84E3C8A0C155EF207056D.jpg[/IMG]
