Where does this go??
Old Jan 8, 2010 | 08:20 AM
98941rb's Avatar
98941rb
Default Where does this go??
'07 FLSTF
Throttle-side switch housing...
After I opened it to tuck wires, this folded piece of copper came falling out.
Any ideas as to where it needs to go?
Thanks for any info...
Old Jan 8, 2010 | 08:27 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
That is the shim for the brake light switch.
Old Jan 8, 2010 | 08:43 AM
98941rb's Avatar
98941rb
OK, will re-examine tomorrow... thanks for the tip, sir.
Old Jan 8, 2010 | 08:47 AM
rbabos's Avatar
rbabos
It slides in at the back of the switch to push it forward toward the lever. Butter knife works good to install it. If it's left out the brake light may not go off.
Ron
Old Jan 8, 2010 | 09:09 AM
dawg's Avatar
dawg
Hopefully you didn't break the switch, that sucker went up in price pretty high.
Old Jan 8, 2010 | 09:10 AM
98941rb's Avatar
98941rb
Thank you, will use that tip as well...
Another newb question if you don't mind?
Pulling throttle cables out of old housing, ended up losing one/destroying the other
little Circlip that sat in groove at terminal end of throttle cables.
I guess these clips help plug & lock the end of the cable guides into the switch/throttle housing...
Can I goto dealer and get new ones? (or do they require a complete cable ***'y)
Or just push it back in there without the Circlips?
Old Jan 8, 2010 | 03:01 PM
rbabos's Avatar
rbabos
Dealer will likely get the clips for you, or if you can go to an auto supply store, some will have small clips to match it up.
Ron
Old Jan 9, 2010 | 09:15 AM
98941rb's Avatar
98941rb
Would I put it there with the folded end down towards the corner,
or folded end facing up & out?
Old Jan 9, 2010 | 10:19 AM
rbabos's Avatar
rbabos
Shove it at the back of the switch, where your arrow is in the pic. Folded end in first. This way the open end flats grab the housing and help hold it in place. Right or wrong, that's what I did, way back when I broke my first switch without reading the manual first
Ron
LowRider68
Sep 23, 2023 06:13 AM
Mike Simeone
EVO
Aug 26, 2018 08:52 AM
Bluraven
Jul 4, 2015 12:21 AM
rideamap
Electrical/Lighting/Alarm
Sep 16, 2014 01:00 PM
pistole
EVO
Feb 8, 2010 06:20 AM
