speedometer ?
d08 shows up on the speedometer.
When cold, just starting up, the odometer flashes. When starting to ride the speedo needle does not sit still. Once warm the system functions as normal. Occasionally while holding a constant throttle the odometer goes blank & the speedo needle can't figure out where it wants to be.
Time to read the electric diagnostic manual (RTFM).
1. Check the speedo. Checks okay. Replace the speedo with a spare. Fault is still there.
2. Check the wiring, even do the verry stupid wiggle test. Fault is still there. Just don't bother doing the wiggle test, it is stupid to think it can find what a multimeter can't.
3. Check the speed sensor. Checks okay. Replace the speed sensor with a spare. Fault is still there. This takes forever & is a pain to take off the stock exhaust to do it.
The speed sensor had lots of gunk on it.
4. Change the transmission fluid. Fluid looks and smells fine, hardly 2k miles on it. Fault is still there. If the fluid smells bad it is a sign the stator has shorted and burned the oil.
5. Check the charging system, rotor & stator. Checks okay. Fault is still there. Remember the oil was good.
6. Check the VOLTAGE REGULATOR. Checks OKAY! Replace the voltage regulator with a spare. FAULT HAS NOT HAPPENED FOR 100 MILES!
Even though the voltage regulator checks okay now, when it is installed it fails intermittently.
After reading the posts here I also checked my headlight. It was fine.
The engine idle has improved, most notibly when at parade speedin in commuting traffic.
