Brake Light Problem
Old Jul 31, 2006 | 11:32 PM
Hound_Dog's Avatar
Hound_Dog
Stage II
Default Brake Light Problem
Hey guys, have a 97 FatBoy. Recently purchased and previous owner had installed a soft tail rear guard. Have just noticed the brake light is permanently on. Both filaments of the bulb are lit. I did try swapping the 2 active wires around but this did not solve the problem. Any help appreciated guys. Thanks
Old Aug 1, 2006 | 12:50 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: Brake Light Problem
That could be as simple as a bad bulb or a stuck on switch. If you use your volt meter or test light, you will easily know if both hot wires are hot.
If not, and it's only the running light hot, replace the bulb. If both are hot, then look unplug the rear brake switch. If the power stays on, it's the front switch. if it goes out, it's the rear.
Mikeinaz
Jul 15, 2018 10:39 PM
FastEddie1200
Electrical/Lighting/Alarm
Oct 30, 2014 02:59 AM
rich1374670x
Sep 17, 2012 10:17 AM
mballard
Shovelhead
May 19, 2012 05:33 PM
Fupl18
Jan 19, 2010 06:15 PM
