Electrical problem
Old Aug 20, 2006 | 11:31 AM
meat wad's Avatar
meat wad
Stage I
Default Electrical problem
I have a 99 FXDWG had it since new, just put a battery in it and the bike died while i was riding it last night. Seems like the battery is not being charged while riding, is this the regulator? Does anyone know how easy it is to replace and how much it is? Thanks for any and all replies. MW
Old Aug 21, 2006 | 11:22 AM
twowheelsforever's Avatar
twowheelsforever
Default RE: Electrical problem
If it's your voltage regulator, it's extremely easy to replace. You may want to check your service manual for the electrical tests to determine if it's bad. If it is, it's only held on by two bolts. Just remove the bolts, unplug the wires, and you're good to go.
Old Aug 21, 2006 | 11:32 AM
sleepneagle's Avatar
sleepneagle
Here's how to check.
1. Regulator. Use a test light with the ground grounded either to the frame or neg post of battery. Touch the probe end first to one side of the plug that connects to the stator. You should get no light. If you get any kind of light the regulator is toast. Do the same for the other post on the plug.
2. Stator check. you need an Ohm meter and set to Rx1 scale. with the two probes touching each of the terminals comming from the stator you should not read higher than .2 Now check by grounding the negative probe and touch positive probe to one terminal in the stator connector and then the other. if you get any kind of a reading, the stator is toast.
vicsponjr
Sep 15, 2019 06:24 PM
tundra
EVO
Aug 28, 2012 06:41 PM
bcolt
Nov 9, 2010 04:13 AM
ewhinger
Sep 19, 2010 06:51 PM
darrinfish
Apr 14, 2010 03:57 PM
