2 questions
Old Jun 10, 2010 | 08:35 AM
  #31
iclick's Avatar
iclick
Originally Posted by St. Bob
What if water entered the connectors after the initial install? Can that be corrected? If so, how?
I've never had this happen even here in S. LA, but you can blow out the water and apply some dielectric grease. The grease should keep water from entering the connector again, and it should be applied at the outset. I didn't use it with my PCIII, which I ran for over two years, but did when I installed my PCV about 15 months ago.
Old Jun 10, 2010 | 08:37 AM
  #32
iclick's Avatar
iclick
Originally Posted by jluvs2ride
A distinction should be drawn between add on units like fuel pak, pcv and tools that reprogram the ECM like TTS and SEST.
The best choice depends on exactly what the individual wants to achieve.
The idea is to provide the proper injector pulse-width (AFR) at the right time (timing), and the injectors don't know if a PCV or one of the flash-based tuners is used. It is simply receiving instructions, so the net result is the same.
Old Jun 10, 2010 | 08:38 AM
  #33
iclick's Avatar
iclick
Those connectors are very resistant to water intrusion.
This is true and they are the same connectors used in the stock configuration.
Old Jun 10, 2010 | 08:47 AM
  #34
iclick's Avatar
iclick
Originally Posted by ChampionHDTech
Secondly the ECM on 07 and up models have Adaptive Fuel Values that adjust for riding style/ load, weather, and wear on bike. SERT keeps this function working properly.
The PCx retains all ECU functions including MAP and AFV, just like the flash-based tuners.
Thirdly the new EITMS (Engine Intermitant Temperature Management System). All the other systems I am aware of disable these functions.
Wrong, EITMS works fine on PC-equipped bikes. All ECU functionality is retained with these devices.
As far as the ECM compensating for changes, it can only change fuel values 3-5% at a time with a maximum of 40%. The main function that determines how rich or lean the engine is running is actually the Ion Sensing. This is done through the coil/sparkplug and read as a hertz value by the ECM through it's clean ground. Yes non OEM plugs and plug wires can distort these numbers and change the way the bike runs. Also attatching accessories to the clean ground can do the same thing. 02 sensors are basically confirming the fuel ratio after combustion has occured. For me anything piggy backing a component is a band aid and more connections increase odds for a connection failure.[/QUOTE]
The ion-sensing function, like all ECU features, is retained after installing the PC.
Connection failure? Thousands of these devices have been sold and used for years. Can you point me to one thread that describes a connection failure other than a very rare report of water intrusion? Water can be repelled by simply using dielectric grease.
There have been a very few reports of bent pins on the connector, but that is easily fixed. I honestly can't understand how you can couple one of these connectors and bend a pin, but it has been done.
Old Jun 10, 2010 | 01:41 PM
  #35
St. Bob's Avatar
St. Bob
Thanks to everyone that hijacked this thread
Old Jun 10, 2010 | 05:59 PM
  #36
scj's Avatar
scj
Sorry
iclick,
It is obvious you don't know near enough about TTS and SEST products to comment and I damn sure know that I do not understand the PCV product very well and, I could care less to know so I'll just step out of this debate.
Old Jun 11, 2010 | 11:15 AM
  #37
iclick's Avatar
iclick
Originally Posted by scj
Sorry
iclick,
I am not an expert on the flash-based tuners and never claimed to be, but I do know enough about them to comment on some statements that have been made here and elsewhere that I believe are not factual. I know much more about the workings of the PCIII and PCV and will also comment on erroneous statements made about those tuners, which is very common here too. I am doing that by asking the originators of these statement to show evidence for their claims, but they never do. Thus, the questions must be asked repeatedly, as they never stop making the claims.
gtbiker81
Aug 8, 2020 06:40 PM
stevenminix
Sep 6, 2011 06:24 AM
1Canuck
Aug 24, 2011 06:19 PM
HDUltra08
Jul 11, 2010 07:41 PM
dhc8guru
Sep 11, 2007 12:25 PM
