Battery Drain
Old Oct 7, 2010 | 03:04 PM
91Heritage's Avatar
91Heritage
Stage III
Default Battery Drain
I've got a (whoa, captain obvious) 1991 FLSTC, Heritage classic Softail. Would a bad or failing Voltage regulator cause a drain on the battery. I just put a new interstate on the bike two weeks ago. No problems until I started doing some carb adjustments, and had to start over and over...which drained the battery to the point that it won't fire. Any suggestions where to start?
Old Oct 8, 2010 | 02:14 AM
mkguitar's Avatar
mkguitar
A bad voltage regulator can allow current to drain from the battery. You would have to test this with an ammeter ( most multimeters have this function).
I'd charge the battery fully- with a battery charger- Trickle chargers ( battery tender) do not offer enough current to charge a battery up- they will maintain a charge.
Once the battery is fully charged you can do all the tests. easy.
info here:
https://www.hdforums.com/forum/elect...d-lighting-43/
Mike
Road Gliderman
Electrical/Lighting/Alarm
17
Feb 24, 2019 12:34 AM
mid30
Nov 18, 2016 05:50 AM
oakmossy
2014-2024 Touring Models
Oct 13, 2015 11:16 AM
econdave
Aug 12, 2009 07:14 AM
I8SMK4U
May 11, 2009 04:18 PM
