Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Some time ago it was mentioned that the PV now has the ability to be powered by a computer for setting gauges and doing other routine chores (except flashing). I have not seen a way to do this, so someone please offer some guidance.
Using the above link for reference, has anyone installed the visor (#61300054)? I assume it will fit with any mount using the PV bolt pattern like my RAM mount, with the assumption you'd need longer screws.
I used it on the Techmount, same bolt pattern and same screws. The clamp mounts just like the PV does.
Ok so i have the AT-100 working and collecting data.
Now my next question is i now get engine light and fault tells me no input from front and rear O2 sensors. I can understand that as i am using the WB sensors now.
How do i disable this fault being recorded so i dont get the engine light on the dash every time?
In those years, you need a set of o2 eliminators from fuelmoto.
Beast is right. You'll need to install the O2-sensor eliminators, which I'm surprised are not included in the AT-100 kit. Mine are holdovers from my PCV, as is the AT-100, so I didn't buy the current AT-100 kit intended for use with the PV. IIRC, all '07-'09 bikes need them, but although later models will not activate the check-engine light they will throw historical codes if the sensors are disconnected without adding the eliminators. That won't hurt anything.
Attach the PV to the computer (PC link mode)-->open WinPV-->Click on Powervision at the top of Win PV screen-->select Diagnostic/Test Functions-->Select Exit PC Link Mode
You will then be able to use the PV unit to set up guages, etc. You will have to disconnect the PV and re-connect to the PC before your PC can communicate with the PV unit again.
Thanks guys for that info on the check engine light.
Fortunately i still have the O2 eliminators from the PCV i was running on the bike before installing the Powervision. I'll plug them in tomorrow before tuning again.
The left plot shows the AFRs as reported by the widebands. On the right plot, red is where the VEs are a little lean. Blue is where the VEs are a little to rich. Yellow is real close.
