Power Vision Information Thread
Old Sep 2, 2012 | 04:11 PM
  #3071
Sam2010's Avatar
Sam2010
The new tables exposed from BETA where did it get the numbers to populate the tables? Did they come from whats already there on the ECU? If so I get why you have to plug into bike. If not are those numbers from Dynojet? Those tables already are in the bike right?
I can get through and pretty much understand the new tables under Environment.
But where does the bike get the spark adjust by Air Temp? where does it take that measurement? and where did those numbers in that table come from?
Spark adjust by engine temp where does it get that? that table is all ZEROS. Not to concerned with that if all ZEROS
The only one I do understand is Spark Knock by Head Temp I know where and what that temp is but again where did the values come from that are in that table?
Old Sep 2, 2012 | 04:33 PM
  #3072
Udawg's Avatar
Udawg
I installed the 1174 beta and tried to do an "update tune" and get an Error Loading message. Anyone else getting this?
Old Sep 2, 2012 | 04:49 PM
  #3073
Sam2010's Avatar
Sam2010
Yes read post #3038 and #3048. Its also in the directions in the word doc. that the beta link is in. Same thing happen to me I got in a hurry and did not read close enough.
The short story hook power vision up to bike go to settings then to enter code then put in 319248 follow prompts. Then you can hook power vision back up to computer open with winpv get tune and you will see the upgraded tune with new exposed tables.
Old Sep 2, 2012 | 05:10 PM
  #3074
Udawg's Avatar
Udawg
Thanks Sam, but that's not in the Word.doc file I have at all. I did it per your instructions though and it did update the fields that were missing. THANKS tons.
I still get the error message but it does show the new tables.
Old Sep 2, 2012 | 06:28 PM
  #3075
ColoSpgsMark's Avatar
ColoSpgsMark
You do have you PV plugged into the computer?
Old Sep 2, 2012 | 06:42 PM
  #3076
Udawg's Avatar
Udawg
Yeah, Thanks Colo. Sam2010 got me going with the code.
Old Sep 2, 2012 | 07:25 PM
  #3077
bohica48's Avatar
bohica48
Can someone explain "MAP RPM Bias Front & Rear", it says it is EGR Effect on cylinders. I understand all the other tables but this one is new to me...... Thanks.
Old Sep 3, 2012 | 08:51 AM
  #3078
papifun's Avatar
papifun
solved my problem of datalogging issue - had data log setting to ProX-Y instead of Simple CSV, now i can see in excell all signals... just forwared my findings whom needs to know.
Old Sep 3, 2012 | 09:25 AM
  #3079
Delta's Avatar
Delta
Where do you adjust these settings. It's been so long, I've forgotten.
Old Sep 3, 2012 | 09:58 AM
  #3080
Sam2010's Avatar
Sam2010
Delta, Hook your power vision up to your computer then open WinPv Then go to top header Power Vision click scroll down to Diagnostic / Test Functions Then to Exit PC Link Mode.
Then you can poke through the power vision unit it self and explore set up gauges etc.
