Power Vision Information Thread
Old May 26, 2011 | 05:56 AM
  #451
CrusingHarley's Avatar
CrusingHarley
Originally Posted by iclick
Could all of you with a mounted PV compare the speed you are showing on (1) the bike's speedometer, (2) VSS signal (vehicle speed seen by the ECM/PV) on the PV in the gauge section, and (3) your GPS if you have one? Be careful and don't have a wreck looking at three different gauges while you're riding!!!
I have my speedometer set with the GPS, which I assume is correct, and VSS shows 2-3% slower than the speedometer. This is a problem because the way DJ is programming the MPG-gauge accuracy in the latest beta FW is to use a new parameter called "MPG calibration." This adjusts not MPG directly as it suggests but rather the fuel-used parameter. The beta-FW now has this new calibration available from the PV only (i.e. not WinPV), and when you tweak this and the Speedometer Calibration you will have a correct MPG reading.
The problem is that on my bike if I adjust Speedometer Calibration for MPG the speedometer will not be correct. VSS (changeable with Speedometer Calibration) is 2-3% slower than my bike's speedometer and both are changed with the Speedometer Calibration.
Y'all please check yours and let me know, as I'm trying to convince DJ that doing it this way is a bad idea. If everyone's bike is like mine you will have to choose two out of three gauges to be accurate, as you can't have all three.
I checked mine last night on the ride home. My VSS is 1% slower than my GPS. My GPS and Speedo are in sync with each other.
Old May 26, 2011 | 12:54 PM
  #452
mars636's Avatar
mars636
I just tried to use the log tuner but did not get anything to show up when i tried to calculate the tune. The map i got from fuel moto has my afr set for 14.5 which i believe would not put me into closed loop, do i have to change all the 14.5 cells in my map to 14.6 to go into closed loop for the auto tune basic to work?
Old May 26, 2011 | 04:33 PM
  #453
adsinclair's Avatar
adsinclair
Jamie - I also have a couple of questions (that will hopefully be helpful to others). I will be currently using the AutoTune Basic function.
1. As the previous post asks, does the AFR table have to force closed loop (14.6 cell values)? If so, can I tune similar to TTS by setting almost all to 14.6 to have it sweep all cells?
2. I run a high Closed Loop bias table, between 700 and 800 on most cells. Do you recommend getting closer to 550 for more accurate calculations?
3. If E10 gas is the mostly used (for me it is, locally), what effect will setting the Stoich Value to 14.1 in the Log Tuner Options? Do you recommend using 14.1 or 14.6?
4. Does the logging on the PV have to be in that exact order with only those channels? I normally log the max amount so I have the most amount of data to pour over when analyzing logs.
5. Does the timing analysis advance timing or just retard it? I assume you have to set it high and let it retard it, in order to advance the map.
Thank you very much for your hard work on the product and I'm excited to start experimenting with the Log Tuner!
Aaron
Old May 26, 2011 | 05:04 PM
  #454
iclick's Avatar
iclick
Originally Posted by Sam2010
I second that awesome. Thanks to all at Fuel moto.
I can not seem to save the Power Vision Log Tuner user guide. Not to worried at the moment. I am pretty excited about this.
Download and install this nifty app which will add DoPDF to your printer list. When you select it as the printer it will create a PDF file that can be saved anywhere you want it. It works very well and I use it frequently, including to save the PDF you mention. BTW, it is freeware.
Old May 27, 2011 | 12:49 AM
  #455
Sam2010's Avatar
Sam2010
Thank you that works. Not sure why i used to be able to save. Browser updates i supose.
Old May 27, 2011 | 09:45 AM
  #456
hornhonker's Avatar
hornhonker
Just ordered my autotune cables from FuelMoto. Now I can get my PCV sensors to talk to my PV.
Old May 27, 2011 | 09:55 AM
  #457
Heatwave's Avatar
Heatwave
Member
I have a few questions on the new PV data logger and AutoTune Basic:
  • The AutoTune Instructions suggest making sure key parameters are being saved in the data log file. I removed all parameters other than those listed in the instructions for data logging. Is that correct? I realize that the deleted parameters can be easily added again, but I just wanted to make sure I'm using the right process for limiting the data log parameters to those that are used by the AutoTune Basic software.
  • AutoTune Basic also appears to make adjustments to the spark advance tables based on knock events in both the front and rear cylinders. Should I conclude that AT Basic only LOWERS spark advance based on logged knock events and that it doesn't raise timing if there is no knock present?
  • For the AutoTune Basic to make timing adjustments, should the data logging be done with the Knock Retard turned OFF in the operating tune file while collecting data?
Thanks for any feedback as I plan to start data logging this weekend and some preliminary AutoTuning (Basic) this weekend.
Old May 27, 2011 | 10:55 AM
  #458
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Aaron
If you are using PV Tune Basic the area you are tuning must be set to 14.6 or on Lambda calibrations .980-1.02 Lambda which will enable closed loop.
On AFR calibration we generally set the bias table to 700. The stoich value in PV tuner applies to Lambda based calibrations, on AFR calibration you control this with the bias table manually.
You can log as many channels as you want and they do not need to be in order, however the more you log the larger the files become and PV log tuner will take longer for them to load and calculate the edits. I recommend for best results logging the basic required channels and if needed adding a few of your own if desired. I have found logging in 15-20 minute sessions works about the best.
Because the timing is corrected using the adaptive knock retard, PV tuner is only able to correct it by removing advance based on knock events. You can generally watch the events and start adding in 2-3 degree intervals.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old May 27, 2011 | 11:01 AM
  #459
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Hello, your first two questions should be covered in my last post. For ignition timing correction the Knock Retard must be turned on and active
Old May 27, 2011 | 01:10 PM
  #460
iclick's Avatar
iclick
I'm not sure, but I think in the creation of PDF documents you can offer a save option or not, as I see it both ways when viewing PDF's on-line.
