Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
What bike are you working on? 14.2 is just above .800 mv. Why would you even consider running an 02 at that voltage? All this has been covered many times. Best if you spend a few hours studying up on this stuff. I'm not trying to sound negative. But with those kinds of questions I wouldn't be messing with any bike just yet. Take your time and study up so you can learn in some sort of orderly fashion.
Let me rephrase it.
The stock clb settings are .964-1.023 (14.2-15.0) I'm assuming that any cell in the afr that falls within those parameters will be in closed loop.
So theoretically if I were to set the clb to .748-.816 (11.0-12.0) any given cell in the afr that falls within that range would be closed loop (I doubt the NB02 sensors would be capable of this).
I'm just trying to get clarity on the relationship between clb and afr, my bike is running great and I have no need to mess with it.
Thanks , but in the airflow section ,then idle speed there are different idle speeds and temps. Which line in there do i change to lets say 900rpm for my warm idle.
Thanks
On my tune I would change all the values in the 205* and greater temps. There is a cautionary note that idle speeds below 900 rpm can cause oil pressure to drop.
Don't think I'd bother to change that. Your engine won't spend too much time at that step I would think. I never changed my rpm's, I'm content with the stock configuration.
Thanks
900 is too low. 975 is just about right on most I've messed with. It will never sound like a Shovel so don't try to make it sound anything different than a TC sounds like. Do what's right for the engine, 900 isn't that. You have both oil pressure and voltage for the FI system to consider. Both of which will be affected by a low RPM at idle.
Let me rephrase it.
You really need to read up on what CLB is. You also need to read up on when your cal is in open loop and when it's in closed loop. Not going to give you the answer lol. When you read up you'll understand why CLB doesn't pertain to your cal. A little reading will clear this all up for you and you'll answer your own questions. That's a better way to learn than taking the easy way out and expecting an answer. Come back and explain what you learned and then I'm sure someone will chime in.
