Power Vision Information Thread
Old Dec 6, 2014 | 08:15 PM
  #6731
FinalShot's Avatar
FinalShot
Originally Posted by Smokey Stover
Yea, you can get multiple licences for each bike you own if your a collector. Better than buying a new one if you trade up.
I knew about the two ways... Buy a license for a second bike or buy a license for $199 that unlocks it and then you have to buy a $199 license for each bike. I guess I learned something new and that you could essentially remove the old bike and put the new bike in for $199.
Old Dec 6, 2014 | 08:19 PM
  #6732
FinalShot's Avatar
FinalShot
I did not know that, (ya learn something new every day) With LT you could only see the hit counts after loading the data logs into LT.You are on the right track. Seeing the green screen would be great.
With the wide band set up you should be fine, Even be able to use the VE adjustments as well. They should be very small anyways at this point1% 2% I was a bit overwhelmed by it all at first so I worked on small areas instead of the whole table at once. Definatly pull 2 or 3 deg for saftey afterwards. I also did some manual smoothing/blending.And comparing similar tunes tables from FM and DJ.That seemed to really make a strong powerband without surging or flat spots.
This method seems to be working for me. I bumped up Max VE to 5% and allows me to track the cells that the timing hits. Much easier than just guessing. I'll look at the tune a little later on.
Jamie, you have more sway with DJ than I ever would but here's an idea for a firmware update. Allow the PV to either select a timing data log screen or even if you place Max VE Learn to 0%, allow the green screen cells to populate. Just a thought...
Old Dec 9, 2014 | 05:38 AM
  #6733
gargoyle13's Avatar
gargoyle13
Default untitled.pvt
When I use the button 'Get Tune' on my computer to download a tune from my PV1 Power Vision the available tunes on the PV units window pops up with their names but when the tune is downloaded onto the computer and you look at the tune in any window, ie; VE, AFR, Spark etc; the tune no longer has its name and is labeled as 'untitled.pvt'.
Has anyone seen this before?
Old Dec 10, 2014 | 10:18 AM
  #6734
captdave221's Avatar
captdave221
yes that is normal. if i gave you my PV and you hooked to your computer and got a map off of it and it was named the same as one of your maps it could overwrite your map. so it gets a copy as untitled and you need to save it "save as" function. understand the idea behind their thinking?
Old Dec 10, 2014 | 04:38 PM
  #6735
gargoyle13's Avatar
gargoyle13
Thanks Captdave221 I now understand their logic.
Old Dec 11, 2014 | 04:08 PM
  #6736
prostar's Avatar
prostar
My bike was tuned by a tuner in town who is known for good work. He is very familiar with Powervision. After tuning my bike I have a POP when the rpms drop to 2000 during a shift. If I keep the shift point higher than 2000 no POP. When engine braking engine runs smooth. Any ideas on what I should be looking at? bike is 2013 limited, SE heavy breather intake, Fuel Moto 2-1-2 head pipe, SE slip on with full sac 2.25 cores. I am wondering if engine needs more back pressure in the exhaust.
Old Dec 11, 2014 | 04:09 PM
  #6737
UltraNutZ's Avatar
UltraNutZ
Decel enleanment table at 2k rpms
**EDIT**
forgot PV doesn't use Decel Enleanment like I'm used to with TTS. Does it do it even with the engine cold? If so, adjust that entire decel enleanment table down by 5%. If only when the bike is warmed up, then I would say try adjusting only from about 200° through 320° down by 5%
Old Dec 11, 2014 | 05:00 PM
  #6738
prostar's Avatar
prostar
This is what Decel Enleanment looks like now
F Multiplier
3 0.55
32 0.5
61 0.45
90 0.40
118 0.35
147 0.25
176 0.20
205 0.20
234 0.20
262 0.20
291 0.20
320 0.20
Old Dec 11, 2014 | 05:36 PM
  #6739
FinalShot's Avatar
FinalShot
F Multiplier
3 0.55
32 0.5
61 0.45
90 0.40
118 0.35
147 0.25
176 0.20
205 0.20
234 0.20
262 0.20
291 0.20
320 0.20
You need to enrich your fuel at the 20 map and 1500 to 3000 rpm range in the afr table. I'm on my phone or I'd include good numbers to use.
Old Dec 11, 2014 | 09:03 PM
  #6740
prostar's Avatar
prostar
Finalshot 20 Map currently
1500 13.7
1750 13.8
2000 14.2
2250 14.4
2500 14.4
3000 14.4
