Power Vision Information Thread
I haven't dug into the timing like you have, but it looks like I may need to. I just tuned until I got to no more changes.
I still do find it strange that your VE dialed in that quickly. You should still be seeing changes fairly constantly but within the +/-2 range. I would almost be tempted (were I you) to make a new route... a bit longer than the current, and start that map over. Hell, I would almost say reset the ECM, put the stock calibration on it, then dump the FM base map on and rerun it.
Did you have the bike tuned via Dyno after the work was done?? I'm not sure if using basic auto-tune will adjust fully for the cams and heads. If you had it dyno'd did you pull the data from the other tuner's tables?? It may not translate correctly, I'm not sure... Jamie would have more clue on that than I. Or did Jamie give you a map FOR your bike with the work done on it?
I had Yellowstone HD install V&H double barrel staggered pipes and do a dyno on it. Much better response and also sounds like a Harley now.
Bob
All the rest should have data. Lambda1 & 2 are only used if you have the wideband sensors. If any of that data is missing, you would not get any tune changes.
When you run the PV Log Tuner, once you verify the options are set correctly, then you open the correct value file, then load a log file and calculate tune, you should be able to go under the tuning table table drop down and see how many hits are recorded in each cell. Are you seeing that?
And yes I see the hits at any given value in the tuning table. It just records no changes. I dialed in timing the same way. I kept going until I got zero changes.
The bike runs really well, I'm just having problems with a lazy throttle in the lower half of the RPM range which makes me think I pulled too much timing out. Above 3k is good and above 3.5k the thing is insanely quick to redline.
If you are using a calibration that does not have the latest tables or new features you can use the following procedure to expose these tables 1) make sure you have the latest firmware and software with the update client 2) flash your calibration to the ECM 3) on the PV unit go to the tune manager and Load Current 4) connect to WinPv and retrieve this calibration from the tune manager and all of the latest tables and features will be exposed
Regarding moving the data from the FM tune into my stock tune...that really wasn't my first choice. But the gear indicators on my speedometer didn't work correctly when using any variation of the FM map, and they did work using the stock map. This was even after making the gear ratios in the FM map match those in the stock map. I figured I'd try my solution, since it only took a few moments, and when it worked, I forgot about the issue and drove on. Probably I should have called and spoke to you about this, but I really didn't want to waste your time on a problem I no longer had!
I believe you, however, when you say that this is a bad idea in general. If you think it's warranted, I'll go back and start over with my original FM map, but I'll need some ideas on how to fix the gear indicator issues. I discussed this problem back on posts 444 and 464 of this thread.
Art
Question about gauges. I am preparing to do my first data log runs this weekend. I have the PV wired, selected the signals to record, and chose a gauge template to view with key signals. Rode in to work today and decided to view the gauges. Got the gauges up and running, but didn't select "Start Log". After about 10 minutes, the gauges disappeared and the PV reverted to the main Data Log menu. I would like to just view the gauges without data logging every time. Is this possible, or do I just log. Would be nice to keep track during all day rides and longer trips. Thanks for any advice.
TedMan
TedMan
