possible electrical problem
Old May 5, 2011 | 08:56 PM
low5sportster's Avatar
low5sportster
Stage II
Default possible electrical problem
Heres my situation, i have a 2005 sportster 883 low. Just recently when i would turn the ignition to "on" press "run" and the try to start the bike, it seems like all power is lost. Then when i turn the key back 1 notch to "acc" only the odometer comes on. The battery is only 2 weeks old, and read 12.88 volts.
Today when i turned to key to "on" the headlight turned on very dim and started getting brighter as did the speedometer indicator lights, but the bike would not start.
anybody have these symptoms, if so what could the problem be?
Old May 6, 2011 | 04:37 AM
takamine4's Avatar
takamine4
When you changed the battery, are you shore you connected it right, + on red, - on black?
Old May 6, 2011 | 08:14 AM
UltraNutZ's Avatar
UltraNutZ
sounds like bad battery connections. Can you verify that you have a good solid ground connection between the battery and the frame on both ends. Also verify that you have a good solid connection between the battery and the starter relay.
If this is all good, I would be looking at the voltage regulator next.
Hope this helps,
Ultra
Old May 6, 2011 | 02:10 PM
TFTCAR's Avatar
TFTCAR
Smile
This really sounds like a bad ground. Have a real close look at the frame ground, it only takes a little corrosion or a loose fitting to give you the type of grief you are describing, good luck.
Old May 6, 2011 | 02:34 PM
Dallas 13's Avatar
Dallas 13
Does the starter turn the motor? If not, I would check the solenoid first.
The voltage regulator only takes effect after the motor is running and the stator is making power.
Old May 6, 2011 | 08:11 PM
low5sportster
Stage II
took battery out and put back in and it runs, might have been the bad ground
thanks for the help.
Jody858
Jan 12, 2025 11:36 AM
Wezdog
Feb 20, 2013 05:06 PM
Somber Goat
Sep 30, 2008 04:47 PM
hdpearson13
Ironhead
Dec 3, 2007 07:16 PM
nycgroov
Nov 20, 2005 07:33 PM
