replacing stator= replace rotor ?????
Old Jun 1, 2011 | 11:45 PM
joesnextoy's Avatar
joesnextoy
Default replacing stator= replace rotor ?????
helping a friend with his 96 badboy and he has figured out the charging issues he has is the stator
my question is when you replace a stator do you =
replace the rotor or
test the rotor (if there is a way) or
leave the rotor alone and just replace the stator
thx
Old Jun 2, 2011 | 06:42 AM
JohnnyC's Avatar
JohnnyC
If you are using a stock stator designed for your bike you should not need a rotor too unless there are visible signs of damage. The magnets are permanent.
Sometimes you may have a stator that falls apart and will damage the rotor, but it would be obvious.
Often stators go bad because they are under rated for the updates and additional electric items added like running lights, or additional tail lights. They also die when the battery stops holding a good charge and draw too much from the stator while the bike is running. And then there's simple things like the regulator plug corroded, bad ground, or damaged / shorting wiring.
Be sure you trouble shoot it thoroughly before cracking open the primary.
One hint of a bad stator is burnt transformer smell in the primary oil.
Good luck, I hope it's a simpler issue.
Pothole914
Mar 2, 2017 10:30 PM
FXD2003
Electrical/Lighting/Alarm
Feb 20, 2017 04:58 PM
tuekwik4u
Nov 21, 2016 12:14 AM
BB4xl
EVO
14
May 25, 2010 04:39 PM
twistedcherokee
Aug 13, 2009 07:53 AM
