popping
Old Nov 2, 2006 | 05:12 PM
portuguese619's Avatar
portuguese619
6th Gear
Default popping
I have a 1995 heritage softail, I got it used about a year ago and the exhaust slip-on had raddled in it so I got set off e-bay and the bike started popping, more it was popping from the start and seem to level out at about 70mph. so purchased a dynojet kit the bike runs great now but the popping seem to have got worst, I checked the plug reading and it seems correct, is it normal for Harleys to pop during deceleration, the slip on's seems to be near straight through? Any ideas or suggestions
Old Nov 2, 2006 | 07:36 PM
dawg's Avatar
dawg
Default RE: popping
Did you check all the fittings in the exhaust? If you have a loose connection somewhere it can cause popping. What do your plugs look like, are the whitish gray or black and sooty?
Old Nov 2, 2006 | 09:32 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: popping
From your vague description it sounds like you hasd a cough or spit out the air cleaner that got cleaned up with the jet kit and you are describing a second popping concern on decel. If your pipes are straight through, it is very possible that you will experience a great deal of popping on decel. This does not mean you are jetted incorrectly, it has to do with the air going back into the exhaust combusting with the fuel being drawn out of the carb on decel.
95ci springer
Exhaust System Topics
May 15, 2015 06:59 AM
RustyCage
Aug 7, 2014 04:10 PM
portuguese619
Dec 27, 2013 03:12 PM
BaldHOG1222
Aug 3, 2012 04:32 PM
zenwarrior
Aug 22, 2006 05:32 PM
