WIRING FOR APES
Old Nov 7, 2006 | 09:21 AM
ACE75's Avatar
ACE75
Default WIRING FOR APES
I bought some 12.5 buffalo bars and extended my control wiring. Now i can't get it through the bars. No matter which way i go it stops at the same spot. Any tricks to this.
Old Nov 7, 2006 | 09:31 AM
rh8234's Avatar
rh8234
Default RE: WIRING FOR APES
If you can get a string through the bars (use vacuum to suck it through) and tie it to your wiring and pull the wires through with the string. Also you might want to lube the wires a little.
Old Nov 7, 2006 | 09:43 AM
Denbo's Avatar
Denbo
Tape up all other open ends other than the ones you are using spray a little silicone spray on them and follow the rest from rh8234.Works like a charm.
Old Nov 8, 2006 | 09:24 PM
DGlide04's Avatar
DGlide04
WD40 also works pretty well. Whatever you use as a lube, make sure it evaporates and doesn't leave a mess behind. The string and vacuum trick works like a charm. The bars don't have the late model dimple in them do they? That would prevent the wiring from passing through. Look at the bars closely and see if the tubes are perfectly round all the way down or if there is a small flat spot on the lower edge.
Angie D300
Jun 15, 2013 11:48 AM
asg13
Mar 17, 2012 11:32 PM
tomzilla
Apr 7, 2011 05:59 AM
0ut1aw
Mar 14, 2008 11:32 PM
misterrick
Mar 7, 2007 05:20 PM
