08 STreetglide ECM codes
Old Sep 15, 2011 | 07:28 AM
rumble0410's Avatar
rumble0410
Stage I
Default 08 STreetglide ECM codes
Can anybody give me a hand identifying the following codes? p1510,p2127,p2138?
Old Sep 15, 2011 | 01:32 PM
UltraNutZ's Avatar
UltraNutZ
https://www.hdforums.com/forum/elect...tic-codes.html
P1510 EFI Limited Performance Mode
P2127 TGS2 Low/Open
P2138 TGS Correlation Error (Twist grip sensor)
Old Sep 15, 2011 | 10:54 PM
shr1966's Avatar
shr1966
Stage IV
I was having issues with the same codes popping up on my 09 street glide. The bike would go into limp mode and I would have to reset the codes before it would work right again. I changed the twist grip sensor, cleaned the pins on the ECM and the connector on the throttle body. None of these helped, I started pulling fuses from the fuse box one at a time and found that nearly all of them had white corrosion (bad) and some had soot as if they had burned. I cleaned them all up, reinstalled and codes finally cleared, bike runs fantastic now. Have put nearly 200 miles on it since and no issues. I obtained a harley service bulletin from a local non HD shop and it talks about all of these steps not including the fuse box. My bike is not under warranty and I didnt want to start changing $500 parts just because the dealer recommended it. There is a known problem, but Harley just doesnt want everyone to know about it unless they ask, then they are pretty vague. Hope this helps.
Hausguy
Aug 21, 2017 11:23 AM
Hausguy
Aug 21, 2017 10:30 AM
Hoosier bird
Feb 25, 2014 06:07 PM
PappyUSMC
May 7, 2013 10:21 PM
anicely
Feb 9, 2013 09:17 AM
