fxdwg charging problem
Old Jul 16, 2005 | 10:25 PM
sandersnc's Avatar
sandersnc
6th Gear
Default fxdwg charging problem
I have a 95 Wide glide and went to ride today and the battery was down. Recharged the battery and checked the voltage to the battery. I can only read 12.82 volts at about 2500 RPM's. I did all of the tests in the Harley manual on the regulator, the stator, and AC voltage output check and the resistance values of the stator and all check ok per the manual. What is the normal charging voltage? I thought it would be like a car 13-14.8 volts. Any one having any ideas will be appreciated.
Thanks in advance,
Jeff
Old Jul 16, 2005 | 10:32 PM
HDF Tech's Avatar
HDF Tech
Default RE: fxdwg charging problem
Jeff
Normal charging voltage is around 14.5 +- when everything is working properly, don't forget you have a draw from the lights etc when idling but you should see this number with some rpm's for sure, How old is the battery?
Old Jul 17, 2005 | 12:51 AM
sandersnc's Avatar
sandersnc
6th Gear
The battery is 3 years old. I am going to have it tested tomorrow at Advance auto to see if it fails a load test.
Old Jul 17, 2005 | 11:56 AM
HDF Tech's Avatar
HDF Tech
3-4years is all some get out of a battery, chances are you may get better life out of it if you use a battery tender when not being ridden.
Old Jul 17, 2005 | 12:51 PM
pilot1996's Avatar
pilot1996
I'd lay odds it's your battery
Mac
Old Jul 20, 2005 | 07:53 PM
sandersnc's Avatar
sandersnc
6th Gear
Turned out to be a weak stator. Installed a new one last night and everything is back to normal.
Thanks for the advice.
Old Jul 20, 2005 | 08:17 PM
HDF Tech's Avatar
HDF Tech
Glad you're up and running again
Old Jul 23, 2005 | 01:54 PM
pilot1996's Avatar
pilot1996
Well shoot...I woulda thunk battery after 3 years on it...glad your back in action.
Mac
Old Jul 23, 2005 | 03:13 PM
HDF Tech's Avatar
HDF Tech
Doing the stator test sometimes fools people into thinking it is good when it will not carry a full load.
Old Jul 24, 2005 | 01:27 AM
John TN's Avatar
John TN
Mac,
With the improvement in battery technology and components if kept properly charged ie battery tender when stored and maintained they last a lot longer today.
John TN
