Speed sensor
Old Oct 14, 2011 | 07:23 AM
KY HDRider's Avatar
KY HDRider
Default Speed sensor
My brother's 2000 Ultra has a problem with his speedometer and radio volume. While riding after the bike heats up, the speedo drops to 0 and the radio volume drops. I suspect the speed sensor, it would cause both symptoms I believe due to the AVC signal to the radio and the loss of pulses for the speedo.
I have a spare speed sensor from my 2004 Ultra that I changed for a different issue. The sensor was not the problem, so I have a good sensor.
Will the sensor from a 2004 Ultra work on a 2000 Ultra?
Thanks.
Old Oct 14, 2011 | 10:39 AM
Mr. Wizard's Avatar
Mr. Wizard
Sorry that I can't answer your question, don't have a part book at hand but...
Had the same issue with another bike. Speedo dropped out and the radio stopped playing. This was an erratic issue and only happened when the bike would warm up while riding.
The bike owner changed plug wires which changed his ION knock system resistance. This affected the speedo and radio. When he went back to stock HD wires the issue went away. I know it sounds weird but I saw it with my own eyes.
Are you running non stock HD plug wires? If so, pardon my interruption.
Old Oct 15, 2011 | 12:45 AM
poppavein's Avatar
poppavein
Have you already removed the metal filings off the speed sensor? They have to be cleaned off occasionally.
Old Oct 15, 2011 | 12:21 PM
KY HDRider's Avatar
KY HDRider
Yes, he has only had the bike worked on at Harley dealers, so I am almost certain the plug wires are stock.
I did remove the sensor and clean shavings, no help.
Thanks.
Old Feb 17, 2012 | 07:43 PM
drs0413's Avatar
drs0413
I am having the exact same problem, speedo goes to 0 and volume of radio drops. Have cleaned speedo sensor a couple of times, no help. Had it in at the dealers and asked them to look at it, within a mile of shop it started doing the same thing again. Plug wires are stock, but may put new ones on as probably need them anyway. 04ULTRA did your brother get the problem fixed on his bike and if so what did he do to fix?
Old Feb 24, 2012 | 02:09 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by 04ultra
...Will the sensor from a 2004 Ultra work on a 2000 Ultra?
Thanks.
Yes it will, same p/n; 74430-00D
mfd#1
Sep 2, 2018 02:59 PM
pp6000v2
Mar 19, 2014 03:41 PM
hollandcrew
Sep 7, 2010 08:20 PM
tbrown2
May 9, 2009 11:49 PM
Snipman
Jun 2, 2008 05:43 PM
